Belt squeal
Old Nov 11, 2023 | 02:45 PM
Vette Ski's Avatar
Vette Ski
Default Belt squeal
Hello,
I know this is not the place for C 5 info but a quick one. My friends 2004 C5 belts squeal when he first starts it but shorty after the squeal goes away .
Thank you in advance.
Rich K
Old Nov 11, 2023 | 10:52 PM
You'e right, it is not the right place. Moved this to C5 Tech for some assistance.
Old Nov 12, 2023 | 10:46 AM
jd911's Avatar
jd911
New GoodYear Gatorback belts fixed my light squeal a few years back.Check pulleys, including lower harmonic balancer, while you have the belts off.
Jim
Old Nov 12, 2023 | 11:14 AM
UstaB-GS549's Avatar
UstaB-GS549
I just went thru this exact problem with mine. Most likely it is one of the 4 idler pulley bearings. Two plain idlers and 2 idlers mounted on belt tensioners. It could also be the belts or antifreeze on belts.
I replaced both belts, 2 idlers and one tensioner for about $150 and an hour of my time. To be fair, I might have gotten by with only replacing the A/C belt and idler.
I just posted my experience:
https://www.corvetteforum.com/forums...post1607231096
Old Nov 12, 2023 | 11:57 AM
bookyoh's Avatar
bookyoh
Originally Posted by Vette Ski
Hello,
Rich K
The simplest first step is to clean the pulleys and try the Gatorback belt. I did that, along with a tensioner and idler pulley change, 4 years ago and my chirp/squeal has not returned. I do recall it took some searching to find the Gatorback belt because the name or manufacturing had been sold off. From what I can tell from my records, I used the Continental 4060798 belt.
Old Nov 12, 2023 | 05:07 PM
Vette Ski's Avatar
Vette Ski
I checked with him today and nothing has been changed as yet. We will change the tensioner and belt in the upcoming weeks.
Rich
Old Nov 12, 2023 | 08:33 PM
RedC5's Avatar
RedC5
My AC idler pulley was the major squeak culprit. I think being low it degrades faster with water etc. Replaced belt and pulley and all is good.
Old Nov 13, 2023 | 04:31 PM
jamieo's Avatar
jamieo
I think the Gatorback belts were replaced with Continentals.
To Belt squeal
