Fair cost for nitrous system?
Old Jan 23, 2003 | 06:34 PM
Lynn2008's Avatar
Lynn2008
Default Fair cost for nitrous system?
What is a fair drive out cost for full nitrous set up for a automatic 00 vert?
What kind of HP and 1/4 gains can I look for on a 100 or 150 shot? And what should I install, as in what manufacturer and should I use wet or dry spray? Thanks, I know nothing about the subject. :cheers:
Old Jan 23, 2003 | 06:38 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Fair cost for nitrous system? (ericg320)
A properly installed system with all the safetys can easily run between 2 and 3K. A 150 shot should easily see 11 seconds in the 1/4. What gets expensive is some of the accessorys such as a remote bottle opener, heater, gauges, custom switch panels, window switches.. I would go with a wet kit because they are far easier to tune on a dyno. good luck :seeya :seeya
