I Gave Up!
Old Jan 23, 2003 | 10:47 PM
PM - NOS - BOOST's Avatar
PM - NOS - BOOST
Default I Gave Up!
Well I finally gave up the start of the season is just to close I needed to make a decision on what was most likely going to get me in to the nines this season and consistently. The cog system continued to give us lots of problems. So I decided to go with spray for this upcoming season the ATI system is up for sale cheep. You can find it posted in the C5 parts section.
Old Jan 23, 2003 | 11:31 PM
lost's Avatar
lost
Default Re: I Gave Up! (PM - NOS - BOOST)
I'm curious. Did you use a motor plate in an effort to cure your belt problem. Friend of mine has been successful running in the nines with a Procharger at 25+ lbs of boost. All of his serious racecars use solid plate motor mounts. His latest is nitrous powered and has been in the eights. Which is not too bad for a small block powered F-body....
