Ranges for Gauges, Wha should they be?
Old Nov 21, 2023 | 10:49 AM
57gman's Avatar
57gman
Default Ranges for Gauges, Wha should they be?
I often go thru the DIC and see the temperatures and ranges of battery volts, tire pressures, oil, coolant, etc. I know tire pressures but what should the other ranges be? Is 14.0 volts too high for the battery or the temperature of 198 too high??? Is there a recommended list somewhere?
Appreciate the responses. Thank you!
Old Nov 21, 2023 | 10:53 AM
ThomasR's Avatar
ThomasR
Those are perfect numbers.
