LS6 Rebuild
Motor stalled on me earlier this year. Haven't found the definite cause yet, think it may have been the AC pulley locked up and stalled it. Took pulley off, was able to spin motor by hand. Replaced the compressor and belt, put the car back together and when I drained the oil, I found a broken bolt came out. Dropped the oil pan and found what I'm fairly certain is one of three cam cover bolts. Probably reason I've been getting codes for high pos cam. I had already replaced the cam pos sensor behind the manifold, but still getting same codes.
So, plan to do a cam swap. I'm dropping the whole motor/drivetrain as one unit in both cradles as I have a lift in my garage. I also gotta chase down an oil leak. I replaced the rear main seal last year when I put a new clutch/trans in. The leak may be from there or somewhere on the motor. Plan to rebuild anything/everything on the motor with already having high mileage. Looking at doing a HCI job, maybe new internals as well. I have no numbers goal. Just a fun street car. It already has longtubes, mid pipe, bb bullets, K&N, and stage 5 RPM trans. Rear end is stock, motor is stock.
*This will be my first motor rebuild doing myself*
Cam - Looking at doing a cam motion 227/232 as see it mentioned quite a bit on here and FB groups. Or maybe BTR. Open to other options as well. Also, I'm sure it will be mentioned, but I just replaced the harmonic balancer. So thats one less thing to purchase.
Heads - Should I leave the stock LS6 243s alone, send off to be machined, or upgrade? I'm lost on upgrade options. I can hold my own on most stuff, but I rather not rebuild valve train myself. So if I'm upgrading, I will have a shop do it or just buy new heads that are fully assembled.
Manifold - leave alone or replace? open to options
Fuel - Again, just a fun street car, so don't need very big injectors, whats a good size for 400+ power?
Internals - I will know more once I take heads off. I have no plans to go big or do boost, however, with 250K miles, I feel like the rings would be helpful to replace. So if I'm pulling the pistons out, should I go ahead and upgrade piston/rods while I'm in there?
Unknown - What am I missing? Suggestions
And with it being black friday around the corner, anyone seen/heard of good deals going on with what I'm looking to do?
$800 plus springs if you use your existing valves. I'm not sure if they are letting the 25% Black Friday on CNC services? I'd give them a call. Sales guys there are pretty helpful in my dealings with them.
https://www.texas-speed.com/p-1172-p...-castings.aspx
I think vette4fl was going to use that Cam Motion cam you had your eye on? Should be cool enough in Florida that he's turning wrenches for his cam swap now. He should chime in shortly.
My Tuner said I only needed the stock injectors with my power level (430 rwhp) and that they stayed away from modified and aftermarket injectors due to driveability and reliability issues.
Depending on your hp goals and cam selection the stock intake and TB may be okay. The $$$ FAST 92 intake and LS2 Silver Blade TB really drove up the costs on my project. I'd check with your tuner and get their opinion.
I used Summit parts where able like the standard pressure and volume Oil Pump and LS2 Timing chain they offer. Looking back at it I probably should have went with Summit performance lifters as they are made in the USA by Morel.
I went down several rabbit holes that added considerable expense. Here is a link to what I did:
https://www.corvetteforum.com/forums...-coupe-m6.html
I recommend that you give Cam Motion a call and tell them what your goals are, your plan for other components (gears, heads, exhaust, etc.) and discuss what would make a good combination. If they don’t have what you need on the shelf, they can grind you a custom cam.
Good luck👍
Good luck👍
Cam, heads, intake other mods will depend on budget and goals.
I would add that while machining is expensive these days, driving over your crankshaft is a real buzz kill, lol.
The shop can torque plate the block and do a proper hone, install cam bearings, and hand it back to you nice and clean, ready to screw together.
https://racer.com/2014/07/28/the-per...linder-honing/
If you disassemble the motor mark all of the rods to identify which cylinder they werre in. It is good practice to know where the parts were in the motor. Lifters, pushrods, rockers etc. If you find something that looks off, you have a better chance to put the picture together of what caused it. Also I don't believe we balanced the motor as the rotating assembly was going back where it was.
OEM machining and cylinder wear with the materials and oils used today has come a long way.
