Upper Ball Joint not Going in Straight
Old Nov 26, 2023 | 10:25 AM
NarcoticCow's Avatar
NarcoticCow
Default Upper Ball Joint not Going in Straight
Hello folks,
While taking apart my spindle to replace my wheel bearings, I tore my upper ball joint. I ordered a new Moog K500134 and while installing using a rented Orielly's Ball Joint press, I find that it just starts crooked. Before continuing I took it out and tried again, only for it to go in crooked again. Has anyone had experience with this and what could I do to install it properly and not crooked?
Old Nov 26, 2023 | 12:14 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Not positive that this will help, on a C-5, but in the old days, when replacing ball joints, we'd toss them into a freezer for a couple of hours, the cold temp "shrinking" it a hair. As you seem to be aware, on a C-5, with aluminum spindles, you can't "horse" it into place like you can with an iron spindle. Care is essential.
Old Nov 30, 2023 | 08:05 PM
NarcoticCow
Do you think the freezer technique could still work on the c5? I'll try this tommorrow.
Old Dec 1, 2023 | 07:43 AM
trloh's Avatar
trloh
This freezing will help but if you have created a score or ridge on the mating surfaces you will need to try to mitigate them first. You can't make the bore oversize at all but if there are scores just ease them slightly.
Old Dec 2, 2023 | 11:51 PM
NarcoticCow
Fellas,
I thought I'd post an updated in case someone has the same problem in the future.
I could not get them in even after somewhat smoothing out the mating surfaces as well as freezing the ball joints. I gave up and took the knuckle + Lower A Arms off to a nearby shop and spent $180 on getting them hydraulically pressed in .
So, person with the same problem in the future, I'm sorry I couldn't do better.
To Upper Ball Joint not Going in Straight
