Anti venom mod
I bought my 01 z06 with a short throw shifter. The previous owner thought it was the MGW. I can’t seem to find a logo, as it’s just a short steel rod with a white ball. Anyways, it feels very notchy and I read somewhere about an anti venom mod. What is that? Or is there a way to adjust the shifter?
The anti venom mod will negate the need for the pause and make the transmission shift in one smooth motion of the shifter.
See this site for the details: https://www.toquez06.com/avm.html
There is no need to do this on a C-5 manual transmission unless there is a problem with the shifter or transmission.
If your car does not exhibit the problem, congrats you are among the lucky few. On the other hand, perhaps the original owner already had the mod performed on your car.
Little trick before shifting into reverse, just go into any other gear first without letting out the clutch, then grab the reverse hole and it will slip right in.
Had a couple old veteran truck drivers who always ground going into first gear on new trucks. They insisted there was something wrong with the clutch. I climbed into the driver seat, started the engine, double clutched, and the shifter practically fell into first. The moral to the story is to set the transmission up for a gear, a soft gesture usually gets her lubricated and ready.
Here's what I have to add.
If you have an aftermarket shifter (upper) I would strongly recommend removing it, throwing it fast and far, and replacing it with a stock C6 upper. Also, if there's a "anti-venom" washer between that external detent and the transmission case I would also remove it and make sure to store it in a location where it cannot be recovered (**** can it!).
Mine came with a B&M "ripper" on top of the stock housing. The neutral gate throw was so ridiculously short I once accidentally shifted from 6th to 2nd while burning hot into a 90 degree left sweeping corner and subsequently killed the engine when the PCM saw a massive amount of air passing through the MAF with a closed throttle. The car and I survived, but my underwear didn't fare quite as well.
Long story short, the aftermarket (as well as the owners represented here) has (/have) gotten more than a little carried away with this type of stuff (bolt-on performance and styling mods) for all Corvettes made after '96. Your best bet is to rip what you feel to be questionable out and replace it with the factory hardware. If you're not the first owner, assume everyone who has owned it previously, screwed with things. Mine has had 7 previous owners, and the "joy" I've experienced un-doing previous stupidity has just about poisoned my love for the platform. In a nutshell, stupid is a corvette owner. Don't be an owner, be a mechanic.
Neither me nor my wife could get it over to the reverse gate without frustration, with the Hurst shifter, a washer later it moved over with relative ease.
The B&M a previous owner had installed in mine had such a ridiculously short neutral gate throw that after having driven the C6 factory shifter for a few weeks I would have to say the B&M was unsafe for anyone to use on public streets. I'm not trying to be pretentious, but sometimes you guys (the aforementioned "you guys" being Corvette enthusiasts in general) take things just a bit too far, and then in an effort to one-up everyone else take it a little further. The result is, well, bordering on stupidity.
I have no idea what a factory C5 shifter feels like, but I would bet that a properly functioning one would be a perfect compromise of performance and comfort so your wife wouldn't feel like she was trying to drive a wood chipper that had an 8" vise-grip for a shifter. Not casting any stones, I'm in the same boat with making the car more spouse-friendly.
When I bought the car a few years ago, I didn’t know it had an aftermarket shifter, only that it shifted like “a wood chipper that had an 8" vise-grip”. I only learned it had the Hurst when I took it apart to install the TMOD box. What a piece of junk that was. Still, many of the members seem to enjoy the short throw shifters, even though they require more effort. I prefer a more sophisticated, lol, touring feel.
I'm not an expert on the aftermarket stuff, but I think that black aluminum piece that offsets the shift lever towards the driver was part of the MGW shifter package. But I could be completely mistaken. I've seen it before, but there were probably a dozen different aftermarket shifter offerings available over the years.
