Door lock issue
Old Nov 29, 2023 | 04:07 PM
captain vette's Avatar
captain vette
Default Door lock issue
I can lock the passenger door using the door switches and key fob but I can’t unlock it all I can hear is a clic clic from the door control module
Old Nov 29, 2023 | 09:50 PM
Dads2kconvertible's Avatar
Dads2kconvertible
A relay has gone bad most likely. Pull the module and either replace the relays yourself or send the module out for repair.
Search for c5 corvette door module repair, there are several places that offer the service. ABS Fixer is one of them.
Old Dec 2, 2023 | 08:48 AM
oelarse's Avatar
oelarse
Here is the location of the relays on the door module and the new relays I bought out of ebay when replacing them
Replace both the lock and the unlock relay (same age and wear )
Old Dec 3, 2023 | 01:03 PM
feeder82's Avatar
feeder82
this is a easy repair, and if your not comfortable soldering in new relays, take it to a friendly cell phone repair shop and have them do it
Old Dec 3, 2023 | 03:38 PM
Dads2kconvertible
Might as well replace the window relays too since you have it out anyway.
Old Dec 5, 2023 | 09:53 PM
helphos's Avatar
helphos
Where does that module live when it's not acting up? My key fob will unlock both doors, but the driver's side unlock button will not. Maybe I need to get out my soldering iron.
Old Dec 6, 2023 | 08:29 AM
captain vette
there’s a module in each door behind the door panel
Old Dec 6, 2023 | 08:32 AM
captain vette
can’t see the seller name from the picture
Old Dec 6, 2023 | 10:13 AM
bc6152's Avatar
bc6152
I had the same issue with my driver's door. I sent it out for repair to Maryland. Cost around $50.00 and turnaround a week and a half. Behind the door panel and easy removal. Guaranteed for life. Whose life I don't know... I'm very satisfied with the repair.
https://www.ebay.com/itm/14354766095...3ABFBM5qL4-odj
Old Dec 6, 2023 | 03:31 PM
helphos's Avatar
helphos
Default Door electrics
Thanks for that! When I had a C4, I was always removing the door panel! First to fix window sweeps, then to fiddle with the speakers, and so on.
I've had my C5 for about 5 years, now, so I suppose it's time I became acquainted with the insides of these door panels!
Thanks!
Old Dec 6, 2023 | 10:43 PM
Dads2kconvertible
Paul, I think you have a different problem. The fob and the unlock button should both activate the relay. If the relay is bad neither of them will work.
I think you can hook up a scan tool you can see if the button is sending a signal but I'm not sure.
I can't figure out how to tag C5 Diag in a post, he would know for sure.
Old Dec 7, 2023 | 08:55 AM
grinder11's Avatar
grinder11
@C5 Diag ......
To Door lock issue
