Things That Go Squeak In The Night
I am inclined to update my '03 Z06 in a similar manor, but as I shop around, I see that we now also have poly-graphite, Delrin and 100AF options available these days. I'm not considering spherical bushings, as this is not a dedicated track car. I am familiar with the Delrin material, itself, and I recognize that it is dramatically less compliant than polyurethane, but I've never driven a car so equipped. I've read several accounts of folks happily running Delrin on the street and I expect that I'd be OK with it too, since I live in the South where our relatively well maintained roads have few potholes and frost heaves.
A brief moment of full disclosure: I love to do upgrades and repairs, but I'll be honest, maintenance is not my bag of donuts. I gotta psych myself up to deal with fluids, brake pads and etc. So, here are my questions:
From a maintenance standpoint, are the poly-graphite bushings worth getting, or will I still need to lube them annually (or sooner)? For instance, are they dramatically better than polyurethane in this respect, or only marginally better?
If the poly-graphite bushings are effective and stay quiet, I'm not so sure that I see the value of running Delrin on the street, especially at their price premium. But, I have the same question regarding the 100AF bushings. What is the maintenance requirement like on them? Will I need to do annual cleaning and lubing, or are they more of an install and forget situation?
Put another way, I think I'd be perfectly happy with poly-graphite if they do what it says on the tin and I would only give serious consideration to 100AF if they offer a maintenance-free, or at least a maintenance-seldom ownership experience. What has been your experience and opinion on these various options from a maintenance perspective?
I also had some questions about lubrication. It seems to me that polyurethane suspension bushings drilled for Zerk fittings used to be a thing. Is there a reason I don't see these around? Are folks manually drilling their bushings, or is this no longer a common practice? Is this now no longer necessary due to improved bushing materials?
Also, I mentioned that I had good results back in the day using anti-seize as a lubricant, but I expect that better options are available. If the bushings I purchase do not come with a lubricant (like my 240Z poly bushings), what do you think about using something like HHS2000 (or whatever Wurth calls it nowadays, since they switched to a fully synthetic formula)? Do you have a better recommendation that has worked well for you?
Thanks in advance!
I am familiar with Super Lube and I use it in other applications, but for some reason it never occurred to me to use it with suspension bushings. I have no idea why this should be the case. I suppose I just assumed that its weather/water resistance wouldn't be adequate, so I appreciate you mentioning it. Thanks!!!
