SOMEONE EXPLAIN ME THIS!!!!!!!!
Old Jan 24, 2003 | 09:58 PM
T-MAN's Avatar
T-MAN
Default SOMEONE EXPLAIN ME THIS!!!!!!!!
Just installed headers and corsa indys,drove it for 2minutes came to light and car started back fireing,took off from light drove fine,came to another light,down shifting and poping like crazy.So i got on the car,1st,2nd gear floored it and car starts hesitating and shakeing,what the f***K.So i called up xtreme motor sports,they say never heard of that hapening!Told me to check plugs and wires,so i did ,they were fine.A friend told me he had same problem,so he disconected battery for 10 minutes hooked it back up,every thing worked fine.I got home disconected battery, waited 10 minutes hooked it back up,what da you know it worked!!!!!Car runs great and sounds awsome!!!!Every one i talked to said you dont need to discnnect battrey (THEY WERE WRONG)said computer will adjust.Someone explain why disconnecting battery worked! Thanks!!!!!!!!
Old Jan 24, 2003 | 10:05 PM
SideStep's Avatar
SideStep
Default Re: SOMEONE EXPLAIN ME THIS!!!!!!!! (T-MAN)
ttt
Old Jan 24, 2003 | 10:44 PM
jimhild's Avatar
jimhild
My experience says that disconnecting the battery and then running the Idle Relearn Proceedure is the best way to get the engine running correctly quicker and easier.
:cheers:
Old Jan 24, 2003 | 11:10 PM
batsallover's Avatar
batsallover
Default Re: SOMEONE EXPLAIN ME THIS!!!!!!!! (jimhild)
:cheers:
I needed to do this when I first installed my Blackwing, I already had my Magnaflows. :yesnod:
Old Jan 25, 2003 | 04:33 AM
Maverick's Avatar
Maverick
Hey TMan, great info buddy. Thanks for letting us know. I will definitely will have to rememer this one.
Mav
Old Jan 25, 2003 | 04:40 AM
EHS's Avatar
EHS
What codes did you get?
Post those and it's easier to tell exactly what happened.
Old Jan 25, 2003 | 11:31 AM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
How do you run the idle relearn? I would like to do this cuz I just put on LT Headers.
Old Jan 25, 2003 | 11:55 AM
enloe's Avatar
enloe
Which headers did you install? Are they ceramic coated? The O2 sensors are usually located farther down stream away from the cylinder heads on headers vs. factory manifolds. This subjects the O2 sensors to a lower temperature. The lower temperatures cause the sensors to produce a slightly different voltage for the same A/F ratio. The PCM will freak out for a while with out resetting it. The popping will be reduced and if you install an X-pipe the popping will almost be eliminated.
Old Jan 26, 2003 | 11:14 AM
TooManyIDs's Avatar
TooManyIDs
Default Re: SOMEONE EXPLAIN ME THIS!!!!!!!! (DCBStingray)
From the 2001 Service Manual:
Idle Learn Procedure
The learned idle procedure needs to be done if any of the following events occur:
- The powertrain control module (PCM) is disconnected
- The battery is disconnected
- The PCM loses power
- The PCM is reprogrammed
The engine idle is unstable when the learned idle position is lost.
Automatic Transmission
Perform the following procedure in order to return the learned idle to the correct position:
- Turn OFF the ignition.
- Restore the PCM battery feed.
- Turn OFF the A/C controls.
- Set the parking brake, and block the drive wheels.
- Start the engine.
- Ensure that the engine coolant temperature is more than 80°C (176°F).
- Shift the transmission into Drive.
- Allow the engine to idle for 5 minutes.
- Shift the transmission into Park.
- Turn OFF the engine for 30 seconds.
Manual Transmission
- Place the transmission in Neutral.
- Start the engine.
Old Jan 26, 2003 | 02:35 PM
EHS's Avatar
EHS
Default Re: SOMEONE EXPLAIN ME THIS!!!!!!!! (EHS)
Right now there's a lot of speculation and guessing. If the car ran that rough, then it would have set a code or two, which, if posted, would allow someone to make an intelligent diagnosis.
To SOMEONE EXPLAIN ME THIS!!!!!!!!
