1999 specifically ebcm removal
Old Dec 28, 2023 | 05:56 PM
Cbibb's Avatar
Cbibb
Default 1999 specifically ebcm removal
Hey guys I'm trying to remove the e b c m in my 99 and I can only find post in my searching regarding the newer models. All of the post I find refer to six screws holding on the ebcm but for the life of me I can only find four on my car. Can someone tell me for sure whether the 1999 has four screws or six holding the ebcm on the pump? I removed those four and that sucker sure is stuck on there pretty good Thank you very much
Old Dec 28, 2023 | 08:07 PM
Cbibb's Avatar
Cbibb
Got it figured out. Just wanted to update since I was not able to find anything when I was searching. On the 99 there is a mount that has a nut going to it on the bottom passenger side of the ebcm. Once you remove that nut and mount there is a brass colored piece sticking out where the mount was attached. That takes a Torx driver to remove which is the same size as the other four. Just wanted to update in hopes of helping someone in the future
Old Jul 4, 2025 | 06:48 PM
Jeffro4474's Avatar
Jeffro4474
1st Gear
Cbib,
First, thank you for this post. I tried to remove my EBCM on my C5 and I could not find six bolts either. I did the notice the mount and then stopped to research. I have some follow-up questions. I hope you can answer them.
1) Did you fix your issue?
2) Where you able to open the unit and repair it yourself?
3) Did you drill a hole the case, tap it, and use it to open the case?
4) Is it a total of 5 bolts holding it on or was it just the one mount? I found some for sale and the four bolts on the same side as the mount appear to be holding the unit together.
Thanks,
Jeff
To 1999 specifically ebcm removal
