spark plugs
Old Jan 3, 2024 | 02:55 PM
clutch1's Avatar
clutch1
Default spark plugs
99, ls1..heads cam, full exhaust, z06 intake....what spark plugs do you recommend...?............john...........
Old Jan 3, 2024 | 05:21 PM
spfautsch's Avatar
spfautsch
I don't need to see any of the details you posted to say Denso 4713 / IT16TT twin-tip iridiums. They're expensive, but they'll deliver strong spark far longer than any copper core plug (even the NGK V-Power). They're also hot enough to be self-cleaning. Consider them to be the last spark plug you'll need to install in this particular car.
Old Jan 3, 2024 | 05:41 PM
feeder82's Avatar
feeder82
NGK Tr55
Old Jan 3, 2024 | 05:50 PM
spfautsch's Avatar
spfautsch
I applaud you for choosing a plug with the same heat range as the factory plugs, but any other justifications for this suggestion?
Old Jan 3, 2024 | 09:28 PM
feeder82's Avatar
feeder82
Been using in my H/C motor for years.
Old Jan 3, 2024 | 09:57 PM
spfautsch's Avatar
spfautsch
That's more of an anecdotal argument than a scientific argument.
I won't argue that for the cost the NGK V-Power produces a powerful spark. In testing I preferred it to the factory Delco platinum plugs by a large margin. But it's still a copper core plug and will erode in 25-30k miles. I'm not getting any kick-backs from Denso, but their TT plugs produce just as fat a spark as any copper core plug, and will continue to do so for decades.
Old Jan 3, 2024 | 10:38 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
This is the first I am reading about a TT - TwinTip spark plug, might be a candidate when I do my plugs if they're as good as ya'll are saying..!
Old Jan 4, 2024 | 08:21 AM
grinder11's Avatar
grinder11
It is my understanding that nearly all, if not all, plugs today have a copper core. The electrode and ground strap can still use a platinum tip/pad. Copper cores are not an NGK exclusive today. Copper cores are so common they're hardly advertised any longer. Again, that is what I've researched. I could be wrong, so FWIW...
feeder82's Avatar
feeder82
My reason for using was on the recommendation of my tuner, occasionally changing them is not a issue for me.
Old Jan 4, 2024 | 10:37 AM
spfautsch's Avatar
spfautsch
I guess I used non-specific terminology. The V-Power plugs have copper electrodes.
The only thing special about them over any other non-exotic plug is they have a v groove in the tip of the electrode that causes the spark to originate from different points of that v edge, slowing erosion.
Don't get me wrong, they're great plugs for the price. You can buy three sets for what one set of tt iridium plugs cost. But iridium plugs will last essentially the life of the engine, which is why OEMs have been using them for over a decade.
Old Jan 4, 2024 | 04:10 PM
clutch1's Avatar
clutch1
what GAP? 40?
Old Jan 5, 2024 | 08:24 AM
redzg's Avatar
redzg
NGK V Power plugs have copper cores with nickel electrodes, so sayeth NGK:
https://www.ngk.com/ngk-3951-tr55-v-power-spark-plug
actual copper electrodes exposed in the combustion chamber wouldn’t last virtually any time.
Old Jan 5, 2024 | 10:35 AM
grinder11's Avatar
grinder11
Yes, agreed on longevity. I've run iridium plugs in my LS7 for over 52,000 miles now, and the gaps are unchanged from day 1.......
Old Jan 5, 2024 | 12:45 PM
spfautsch's Avatar
spfautsch
Whatever the case, when I was testing different plugs for my ignition controller the Denso tt iridiums hands-down produced the best looking spark over platinum and single tip iridium plugs. I think I also tested a Bosch that had a fine wire iridium electrode and a ground strap with a platinum "rib".
The OE Delco platinum plugs IMO just suck. The spark basically goes around the platinum, creating a "bubble" of very weak spark. I've pulled these out of high mileage engines and the electrodes will be eroded down to a point around the platinum "puck".
Old Jan 6, 2024 | 09:58 AM
grinder11's Avatar
grinder11
I have no experience with OEM Delco platinum. Mine are-Surprise-Autolite double platinum. They have served me well......
Old Jan 6, 2024 | 10:19 AM
Kingtal0n's Avatar
Kingtal0n
For over two decades in sr20det, rb2xdet(t), 1/2jz-gte, 4g63, 1/2zz, etc... I setup and tuned hundreds of turbocharged daily drivers
Always use the same procedure
https://forum.hptuners.com/showthrea...l=1#post744925
When the engine is mechanically electrically sound we tune on the first set.
Then we install a second set to verify the condition of the plugs after mileage.
Tuning will mark up the plugs making them impossible to read. Marks are OLD news from OLD tuning sessions we don't care about anymore so we get rid of them using a NEW set of plugs once the engine is fully tuned. Then, we drive the vehicle many miles 2000 to 12,000 miles to make sure they stay looking great. Then, finally, brand new iridium plugs go in once and for all now it can go 100k miles no issues.
DO NOT touch the brand new spark plugs with your human hands. It will leave residues, carbon, salt, debris, which bake on causing marks. Use DISPOSABLE CLEAN NEW gloves for handling spark plugs.
Do NOT use anti seize on the first set of plugs for tuning. Residual oil in the threads will prevent seizure in the short time we use them. On the FINAL set of plugs we can use a tiny bit of anti seize but applied very carefully using gloves WAY away from the ends.
Iridium NGK is the final plug. Do not contact with human skin.
To spark plugs
