P1416 AIR System Bank 2
Old Jan 25, 2003 | 03:20 PM
jschell's Avatar
jschell
Default P1416 AIR System Bank 2
Can someone give me some insight on what this PCM code means???
P1416 AIR System Bank 2...I got a check engine light and this was the guilty code.
Please help! :confused:
Old Jan 25, 2003 | 04:03 PM
jschell's Avatar
jschell
Default Re: P1416 AIR System Bank 2 (jschell)
awww come on, this is killin' me!
:eek:
Old Jan 25, 2003 | 04:15 PM
alc2001's Avatar
alc2001
Jeff,
There have been a number of threads on this code. Here are a couple that should help:
http://forums.corvetteforum.com/zerothread?id=455807
http://forums.corvetteforum.com/zerothread?id=454807
Alan :seeya
[Modified by alc2001, 1:18 PM 1/25/2003]
Old Jan 26, 2003 | 10:05 AM
MySea6's Avatar
MySea6
Have you messed with your intake lately?
Old Jan 26, 2003 | 03:21 PM
jschell's Avatar
jschell
Default Re: P1416 AIR System Bank 2 (MySea5)
thanks for the links!
I have not messed with the intake. I cleared the code and the problem has not reoccured. I will be checking my intake and Air lines.
How difficult is it to change Bank 2 air check valve?
Old Jan 26, 2003 | 06:59 PM
Face's Avatar
Face
It's a pain in the butt, you'll probably have to remove the intake manifold. It's wedged between the firewall and intake manifold.
Old Jan 27, 2003 | 03:08 PM
EHS's Avatar
EHS
I just had this happen, and c4c5specialist and I had just "messed" with the exhaust (swapping out the Corsa Indys for PRT to help a friend decide what to do (X-pipe or not, PRTs or not).
While it could be a faulty valve, if it doesn't and hasn't recurred, leave it alone. Check the other spots, but don't look for something to fix.
Old Jan 27, 2003 | 03:23 PM
knkayotte's Avatar
knkayotte
I get this a couple of times a month. Heard its a PITA to change out. Going to wait see what happens.
Later, Keith
Old Jan 28, 2003 | 02:41 AM
jorex's Avatar
jorex
The GM manual states that this code is set when the AIR pump is tested by the PCM during closed loop operation and both of the following conditions are met during pump test operation:
1. The right bank oxygen sensor voltage does not fall below 222mV for at least 1.2 seconds, and...
2. Short term fuel trim does not rise to a predetermined level (value undisclosed by GM)
Basically this means the O2 sensor is not reading enough pump air in the right side exhaust stream. (Alternate bank and dual bank faults set different codes)Some common causes are as follows:
1. Obstructed rubber air line to the exhaust check valve
2. Casting flash in the exhaust manifold (Check where the metal tube bolts to the manifold)
3. Clogged or stuck exhaust check valve
4. Check valve flowing both directions
5. Air leak in the air injection piping
6. Clogged vacuum purge (makes the AIR intake valve lock shut although it is electrically OK)
Others have reported loose exhaust manifold bolts as causing the problem and I can personally report that cleaning and reoiling my Blackwing coincided with the code going away. It also stands to reason that a marginal O2 sensor could also cause this. Also, be aware that this code can accompany (and be caused by) other code conditions such as P0101, P0102, P0103, P0107, P0108, P0112, P0113, P0117, P0118, P0300, P0325, P0327, P0335, P0441, P0502, P0503, and ay O2 sensor related codes. Happy hunting!!
To P1416 AIR System Bank 2
