Engine running without belt
Old Jan 4, 2024 | 08:25 AM
captain vette's Avatar
captain vette
Default Engine running without belt
I can hear a cricket sound coming from the front of the engine at idle I’m suspecting my serpentine belt so I’d like to run the engine without the belt to confirm. Is that possible only for a short period of time. Thank you
Old Jan 4, 2024 | 08:41 AM
sonicss33's Avatar
sonicss33
I see no problem for a short time, just remember no belt means no cooling.
Old Jan 4, 2024 | 08:57 AM
glbeauchamp's Avatar
glbeauchamp
Could also be the tensioner pulley
Old Jan 4, 2024 | 09:31 AM
Hereispappagray's Avatar
Hereispappagray
No issue to run it for 20-30 seconds like that. Please keep in mind that we do see a lot of Harmonic balancer failures on these engines. They will start to separate, causing belt noise. Check that would when the belts off
Old Jan 4, 2024 | 10:31 AM
smitty2919's Avatar
smitty2919
no belt = no cooling no charging no PS.
Won't be an issue for a short time to diagnose. I suspect the car will throw a code since it won't see the alternator charging the system.
Old Jan 4, 2024 | 11:05 AM
hyperv6's Avatar
hyperv6
You will be gone to run it long enough to eliminate or prove the belt is at fault.
I have fired up V8 Chevys on the ground to see if they were any good before buying. No belts no car.
1-2 MINS WILL NOT HURT.
Old Jan 4, 2024 | 11:20 AM
Missileboy's Avatar
Missileboy
Even if it is not the balancer, this is good advice-check it, they wear from age as well as mileage/use. Mine (2002 w/56K miles) was a "wobbler" when I bought the car last Jan and had mine updated when I did the supercharger upgrade.
Old Jan 4, 2024 | 12:12 PM
captain vette
good point.
Old Jan 4, 2024 | 12:19 PM
Moved to C5 Tech.
Old Jan 4, 2024 | 09:42 PM
grinder11's Avatar
grinder11
^^^^^^^This^^^^^^ is truth. Your coolant sensor/temp gauge will tell you accurate coolant temp, as long as it's functioning. I once pitched a belt on a 1974 Camaro 350 SBC. Didnt know until the gauge started climbing. I was 2 miles from home, and went at least 1 mile (at 45mph) before it got over 220°. No damage. Should make guys think about looking at their gauges now and then!! This experiment should tell the tale, at least part of it......
Old Jan 5, 2024 | 12:15 AM
vette4fl's Avatar
vette4fl
To Engine running without belt
