Engine code P0102 fix c5
Old Jan 5, 2024 | 02:05 PM
dominicfrantz's Avatar
dominicfrantz
1st Gear
Default Engine code P0102 fix c5
I’ve had this code up for a few days and I’ve tried cleaning the MAS sensor and even replacing it but when I replaced it it ended up running worse than before. With the old sensor I’d get lag and it would drop rpm randomly and sometimes stall at stop lights. I’ve got the stock air box and haven’t changed anything in the engine recently to cause it. If anyone has any idea let me know. It’s a 2002 c5 base
Old Jan 5, 2024 | 07:57 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Sometimes a dirty throttle body can cause a P0102 to set…I’d check that !!…did you use a new OEM MAF sensor ??…I’d also check the wiring…12 volt power, ground, and the signal wire.
