Speedo not working
Old Jan 8, 2024 | 07:48 PM
rexx78's Avatar
rexx78
Default Speedo not working
After I replaced the clutch on my 03 Z06, the speedometer didn’t work. I found out I didn’t plug in the VSS. I plugged it in, no luck, replaced the VSS, no luck. The VSS plug looks fine.
Now my speedo is pinned; won’t sweep on startup or with my scanner, and HUD does not register a speed either.
Any ideas?
Old Jan 9, 2024 | 12:19 AM
mmartinez's Avatar
mmartinez
You will probably have to inspect the wiring from the vss connector to the pcm,
Old Jan 11, 2024 | 12:51 PM
mmartinez's Avatar
mmartinez
Any luck on resolving the problem? It occurred to me that you may also have overheating problems since the pcm will not turn on cooling fans if your speedometer is pegged high.
To Speedo not working
