My 2001 C5 voltage when the car gets hot in hot weather always drop into the 12's and I have went through a couple of batteries of the last year. Plus I have upgraded with a new touch screen stereo, amplifier, and subwoofer and I just replaced another battery as these upgrades just seem to have made things worse, seems like the OEM 110 alternator is not getting the job done. I have been getting a charging fault error message, for sometime before the upgrade, when I start the car.
I have went through several threads here and the suggestions are all over the place. I want to upgrade the alternator with one that will stay at or slightly above 14 when under load. However I have read that a high output Alternator could damage the computer and will give you a charging fault error message as the PCM isn't recognizing the Alternator working.
I wonder if this 145 amp alternator will be any better?
I wouldn't want my alternator to be putting a constant 14v into my battery. There's a reason we have voltage regulators. A constant 14v will assassinate the battery in probably the same time frame, or less, than you're seeing now. I'm wondering if your voltage regulator isnt doing that right now? As jim993 said, check voltage at the terminals. IIRC, the DIC will provide a lower reading than across the terminals will, because it goes thru the ignition switch. Which may, or may not, have good terminals/connections. My .02.....
You can use any alternator that fits but then you're looking at possible tuning or even wiring changes
The 01 up alternators are supposedly not drop in replacements for the earlier one. The regulator is different.
I wouldn't want my alternator to be putting a constant 14v into my battery. .
All alternators are set to regulate around 14V, typically 14.2V but it can vary with temperature and application a bit. Newer cars let the voltage drop and then charge again for efficiency reasons, not battery life.
You should be getting 13.8/14.2v at the battery when engine is running at all times. If you are getting less it is one of 2 things a bad alternator or bad wiring. Being that you have determined that it is temperature sensitive I would lean to the alternator being bad but would need to do some more checking to 100% know.
If it was mine I would be replacing the alternator and doing a big 3 upgrade. Adding a higher amp alt is beneficial but not necessary for the amount of draw your electrical system is making.
