Long tube Headers - Need some advice
Old Jan 26, 2003 | 01:30 AM
Road_runner's Avatar
Road_runner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Default Long tube Headers - Need some advice
Your comments on any/all of my questions would be very appreciated.
1. What brand would you recommend?
2. Ceramic Coated or not?
3. I had the local muffler shop install the stingers & X pipe. They did an excellent job. Should I trust em with the long tubes?
4. Does the install involve taking the engine off the motor mounts?
5. Any comments on how much louder at idle, cuising and WOT?
6. No problem with resonance now...will the long tube headers be a problem on llong highway trips?
7. How much HP gain should I expect?
:steering:
Old Jan 26, 2003 | 01:38 AM
jmX's Avatar
jmX
Default Re: Long tube Headers - Need some advice (Road_runner)
:steering:
1) I've personally installed FLP's and LGMs and I'd recommend either for sure. The LGM's were a bit nicer and they'll cost a bit more, they wont need coating. I recommend these brands because your stock parts can be set aside so if you ever sell the car, you can remove the headers and put the car back to stock. In addition, since no welding is needed, you can install these yourself in your own garage and save on the $300+ for labor. I should be doing a writeup soon showing how easy it is to install either one of these FLP or LGM headers. I think once people see how easy it is, they'll get headers that dont need welding and end up with a better product for the same price as the others + install costs.
2) Coating is up to you, LGM stainless ones don't need it, the others will most likely come with it.
3) Installing headers is cake. Any shop should be able to do it
4) The ones I've installed didn't.
5) If you leave cats in, a bit louder. If you take the cats out, probably double the volume. It all depends on the combo of the muffler and cats, but its going to be louder.
6) without cats you'll probably get a little more resonance. It'll vary from brand to brand
7) between 15rwhp and 40rwhp, depending on mods and if you put cats in or not.
Old Jan 26, 2003 | 03:34 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Long tube Headers - Need some advice (jmX)
jmX is correct our headers are made from stainless so will not rust like mild steel and do not need to be coated. However we have a few customers jet hoat coat them for appearance and I must say they brought a teat to my eye. Some of the most beautiful headers I have ever seen. Our system is complete from headers to catback and we have swappable v-flanged straight off road pipes, a 3" x-pipe, and high flow cats. For more information feel free to give us a call to discuss.
-LG Motorsports
"Where Money Buys Speed"
972.272.7753
Old Jan 26, 2003 | 04:23 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Long tube Headers - Need some advice (Godspeed)
Stainless Works...........for the quality and price you can't beat them.
Old Jan 26, 2003 | 09:26 AM
billjax's Avatar
billjax
St. Jude Contributor
Never heard of that characteristic but I like it!!! :lol:
Sorry, couldn't resist.... :D
Old Jan 26, 2003 | 09:47 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In VI Veteran
I went with the FLP's for I wanted a true bolt-on solution :yesnod: I am truly satisfied with the quality of the product along with the very noticeable added performance increases. One of the benefits that I wasn't even considering when I made my purchase was how the sound on my C5 changed for the better. A deeper and richer one at that! Good luck with your decision...
Old Jan 26, 2003 | 09:49 AM
ndirishr1's Avatar
ndirishr1
How can I get a teat to my eye too?
Old Jan 26, 2003 | 10:16 AM
NO2's Avatar
NO2
I can think of better places to put a teat :D
Old Jan 26, 2003 | 10:19 AM
mods to come's Avatar
mods to come
Default Re: Long tube Headers - Need some advice (NO2)
:lol:
Old Jan 26, 2003 | 10:27 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In V Veteran
Default Re: Long tube Headers - Need some advice (ndirishr1)
I think he meant to say he wanted a treat in his eye :lol: :lol: :lol:
All kidding aside, I would go with TPIS or FLP.. :seeya :seeya
Old Jan 26, 2003 | 10:39 AM
Road_runner
Thanks :cheers:
This is for your eye
:D
If you remove the cats or have cut outs do you reprogram the engine?
(O2 sensors etc....)
Old Jan 26, 2003 | 10:49 AM
6SHIFTIN's Avatar
6SHIFTIN
jmX you mentioned that LGMs do not need coating. It was later mentioned that they are stainless and will not rust like milled steel which may need to be coated.
I had thought that I had read that coating was also done to deal with heat issues. Is this correct. If so how do the LGMs avoid requiring this.
Old Jan 26, 2003 | 03:56 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
I want two!!! :D
Old Jan 26, 2003 | 04:32 PM
Don&Kelly's Avatar
Don&Kelly
I put Belanger Long Tube Headers on my '00 A4, what a difference in power & sound, much deeper, zero resonance .. very high quality .. Jet Hot coated ... 17-19hp and 19-22trq are typical gains. Normal installation, 4-6 hours (you do not have to disconnect a motor mount) ... only "Tri-Y design with a "pickle". The "pickle" is a device mounted inside each collector, to keep the velocity up, while going through the collector. This increases vacuum, scavenging of the cylinders is more complete, which in turn pulls more of fresh air and fuel back into the cylinder. These really work .. a favorite with "Viper Racers" .. not cheap but very high quality & dependable (I bought some Belangers for a small block chevy 25 years ago) .
Hope I answered all your questions & good luck in making your choice ..
:cool: :cheers: :seeya
[Modified by Don&Kelly, 3:34 PM 1/26/2003]
Old Jan 26, 2003 | 04:49 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
Default Re: Long tube Headers - Need some advice (CHRIS NJ C5)
hey Chris.....why TPIS.....I have a chance to pick up a used set and wanna make the right decision and install once ;) :D
Old Jan 27, 2003 | 12:35 PM
Road_runner
Default Re: Long tube Headers - Need some advice (Don&Kelly)
Don
Thanks for the help
See you at the open road events this year :cheers:
Look for #43 :D
Craig
Old Jan 27, 2003 | 12:56 PM
Don&Kelly's Avatar
Don&Kelly
Graig, whicch races are you attending this season? I'm doing Big Bend in April - Bonneville in June - Arnold NE in Aug & Silver State in September ...
don
Old Jan 28, 2003 | 11:27 AM
Road_runner
Don,
See you at Bonneville and at the Silver State. There is a small chance I can do the Texas trip but 2200 miles one way...lots of missed work, greater chance of something happening to the car on the way...etc...I'm looking into having the car shipped to Texas & driving home.
See you at the Bonneville 100 :cheers:
To Long tube Headers - Need some advice
