Ram Clutch any experience?
Old Jan 26, 2003 | 11:36 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default Ram Clutch any experience?
My Star III is starting to make noise though it doesn't slip, I am going to have to address the HYD sticking clutch, probably with an adj master, diff slave and line, I am thinking I may as well go ahead and do a clutch as well, I am quite interested in the Ram 900 series clutch package which I believe includes the HYD system which should eliminate all my clutch problems, wondering if anyone has any experience with a Ram setup at this point. I am doing internals etc shortly and may as well do something while my car is down and it may save a little labor as well.
Old Jan 26, 2003 | 01:15 PM
Vette#4's Avatar
Vette#4
Default Re: Ram Clutch any experience? (NEPTUNEBILL)
Would like to know any info on this as well !! :D
Old Jan 26, 2003 | 04:19 PM
Phil97SVT's Avatar
Phil97SVT
I have the Ram clutch and love it. It has held all of 620rwtq and 550rwhp on drag radials. On prepped tracks I have seen 1.61-1.69 60's launching easy. I have about 25 passes on the clutch and no slippage or dead pedal.
Phillip
Old Jan 26, 2003 | 05:07 PM
NEPTUNEBILL
Default Re: Ram Clutch any experience? (Phil97SVT)
Phil---Thanks did you get the 900 (maybe its the 910), did it come with MC and Slave etc.--Bill
Old Jan 26, 2003 | 05:15 PM
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
Do you know who has the best price on this? Does it work with the aluminum flywheel. The Star clutch seems like you are buying a problem from what I have seen. Trying to find the best solution the works consistantly.
TIA
Old Jan 26, 2003 | 05:22 PM
NEPTUNEBILL
Default Re: Ram Clutch any experience? (#001 2001 Z06)
My star has started making noise and since I'm doing some serious mods shortly I am thinking about replacing since I have to address the sticky problems anyway it would be very little addional labor to put in the new clutch and you can order the upper end 900 series ram with an aluminum flywheel--and they require their adj MC and their slave(i Think, I'll find out tom.)
Old Jan 26, 2003 | 09:56 PM
bogielake's Avatar
bogielake
Neptune:
I am getting ready for a clutch upgrade myself. I printed out some information from an older thread. I checked the on line catalog for summit racing, I believe the part # was 4021550N for the 402 PPlate and 6130 disc and I believe you would need to upgrade to an adjustable master cylinder.
Cartech has a package for $629 as with your master cylinder as a core.
http://forums.corvetteforum.com/zerothread?id=467599
Brad
Old Jan 26, 2003 | 10:21 PM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: Ram Clutch any experience? (bogielake)
I think $629 is for F-Body cars, check their website www.cartek.net and look in the special/GP section. :cheers:
Old Jan 26, 2003 | 10:24 PM
bogielake's Avatar
bogielake
Default Re: Ram Clutch any experience? (NJVetteGuy)
It now says F Body or C5
Old Jan 26, 2003 | 11:22 PM
Phil97SVT's Avatar
Phil97SVT
I got the 6130 and 402 combo from Summit for like 200 bucks.
Phillip
To Ram Clutch any experience?
