As I get things together for my mild NA build (just waiting on heads at TSP for several weeks) I am looking for anything I come across on forums to save a buck or two if it makes sense. These lifters popped up earlier and wondering if there’s any way to verify one way or another that they’re legit GM not Delphi? Thanks!
IMHO it's not worth the risk. That's really cheap too which is concerning. Valve train (especially lifters) is NOT a good place to save money with the uncomfortable numbers of owners reporting lifter failures. What's worse is if you do have an issue the heads have to come off to change out lifters.
Perhaps consider contacting Brian Tooley Racing for recommendations best suited for your build and budget.
I was in the same process a few months ago. After comparing most of the lifters out there, I actually went with the Johnson 2110R lifters based on recommendations from both my tuner and forum members on here. I'd save up for ones that are of a little higher quality.
Has anyone actually verified that the Delphi and GM lifters are actually different parts? Even if part numbers are different, it means little. Since GM owned, and then spun off Delphi, I think they may be one and the same. There really aren't that many companies that make, or are capable of manufacturing, hydraulic valve lifters. Unless actual data, and proof exists showing they are indeed different internally, I'll bet GM buys them from Delphi, and slaps a different part# and price on them. When you really look in depth at GM, they actually manufacture very little anymore. Most all of their cars parts are outsourced......
With counterfeit parts being out of control I’ll tell you what I did. For a lower cost LS7 lifter I bought the summit racing branded ones. They have two version I bought what the ones they consider HD. Part # SUM-HT217-16
The Pro LS stuff they sell has a great track record and coming from one source it’s a know quality.
Another thing you could do is buy them from Jegs or Scoggin Dickey Parts Center. You might pay a bit more at SDPC, but there's mighty good odds you'll get GM parts, and not counterfeit Chinese junk....
In order a lot of Summit Racing for that very reason.
Says right in the description on the web site SUM-HT217-16 are Morel made in the USA lifters. Knowing what I know now I would have went with those lifters last spring when I did my cam swap. I paid $400 for the GM performance12499225 from TSP when I was ordering my cam kit. I could have saved $200 with the Morel/Summit offering.
I did buy a Summit brand LS2 timing chain and a std pressure/volume oil pump (Melling casting number) when I did the cam swap last spring. 6500 miles on those parts so far and no problems. I also bought all Summit specialty tools to get the balancer off and on plus rocker tools. Quality stuff.
As near as I can determine Morel's entry level street oriented hydraulic roller lifters are made in China, as are most everyone else's $300-$500 entry level roller lifters.
Edit:
Be aware, Morel makes many different types of lifters. If you are winging your LS to 7k plus and high spring pressures these lifters (or any LS7) may not be a wise choice.
This is the reason I went with a low lift cam and single springs. My engine starts losing steam around 6k which is perfect for what I do with my car and my application.
Higher rpm's and higher spring pressures require different parts combinations. Check out this list from Morel: https://johncalliesinc.com/pdf/Types...%20Lifters.pdf
Reason: Added info from Morel
