Need help for loud noise
Old Feb 4, 2024 | 12:13 PM
Tedblane's Avatar
Tedblane
2nd Gear
Default Need help for loud noise transmission or rear end????
I have an 05 Corvette hat had the wheel bearing changed a day later driving down freeway loud noise started coming from rear end could it be something that the mechanic did to make that noise. It does it really bad when I put it in reverse. Sounds like when you try to put a manual transmission into gear and don't push in the clutch.
Old Feb 4, 2024 | 02:30 PM
mmartinez's Avatar
mmartinez
This is the C5 Tech forum, not much changed between 2004 and 2005 in regards to rear wheel bearings. I would return the car to the mechanic who performed the work.
