Rear Diff leaking!
Old Jan 26, 2003 | 11:51 PM
Ja4play's Avatar
Ja4play
Default Rear Diff leaking!
I have a small leak somewhere in the rear end. The car is a 2003 AE has less the 3000 miles on it so going to the dealer for repair should be no big deal BUT has anyone else had a problem and if so what did they find? Just so I have some idea what if the dealer has a cue?? Also anybody in Phoenix know which dealers to use or stay away from...
[Modified by Ja4play, 4:52 AM 1/27/2003]
[Modified by Ja4play, 4:53 AM 1/27/2003]
Old Jan 27, 2003 | 12:08 AM
RichieRich's Avatar
RichieRich
Default Re: Rear Diff leaking! (Ja4play)
This is another one of those annoying problems with the C5 that GM has known about for years and has never fixed. :mad :cuss I and many others on the forum have had this problem. Join the club and have it fixed. :cheers: :rolleyes:
Old Jan 27, 2003 | 12:33 AM
gmblack3's Avatar
gmblack3
Default Re: Rear Diff leaking! (RichieRich)
:iagree:
Old Jan 27, 2003 | 12:01 PM
add's Avatar
add
What is the fix? My 99 has a very small leak also.
TD
Old Jan 27, 2003 | 12:31 PM
Bill Benavitz's Avatar
Bill Benavitz
Default Re: Rear Diff leaking! (add)
Some say replace the rear o-ring seal between the diff housing and the axel shaft. Others have said this did not work for them.
Old Jan 27, 2003 | 12:49 PM
427C62013A's Avatar
427C62013A
Could also be transmission pan. Mine was leaking, tightened up bolts all around pan ever so slightly. No more drips. @ 10,000 miles.
Old Jan 27, 2003 | 01:31 PM
Jochen's Avatar
Jochen
Default Re: Rear Diff leaking! (C5DaveC092002)
My 97 is loosing a very very small amount of tranyoil (i guess). So far no drops on the floor, just the seal a little wet.
I guess i will tighten the bolts a little and see if there will be drops on the floor in the future.
Jochen
Old Jan 27, 2003 | 01:37 PM
Smokin Joe's Avatar
Smokin Joe
Default Re: Rear Diff leaking! (Bill Benavitz)
I had the seal replaced in my '00 under 20,000 miles. Sprayed fluid all over the bottom rear of the car. It took forever to clean.
Old Jan 27, 2003 | 05:20 PM
Depends on where the leak is coming from. My '00 had this problem and they ended up replacing the seal where the half-shaft goes into the differential on the driver's side.
Old Jan 27, 2003 | 05:51 PM
keith5's Avatar
keith5
Active Streak: 90 Days
It is a well known problem. There is usually no need to replace
any seals. It most likely is one of the cover plate bolts.
My "Master Vette Tech" at Casey Chevrolet in Newport News, VA
has repaired dozens of this problem with a simple technique he came up with.
He aslo submitted his findings to GM, but apparently they haven't acted on
it.
:banghead:
Old Jan 27, 2003 | 06:20 PM
FXWG's Avatar
FXWG
Default Re: Rear Diff leaking! (SpyRacing)
MY left axel shaft seal replaced at about 10000 on my 2000. NO more leaks. :auto:
Old Jan 27, 2003 | 06:30 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Default Re: Rear Diff leaking! (gmblack3)
This is another one of those annoying problems with the C5 that GM has known about for years and has never fixed. :mad :cuss I and many others on the forum have had this problem. Join the club and have it fixed. :cheers: :rolleyes: :iagree:
:withstupid:
Driver's side leaked @ 23k. Fixed under warranty.
Old Jan 27, 2003 | 09:58 PM
Ja4play's Avatar
Ja4play
Well, I guess it's good to know that I'm not the first one with this problem. :confused: It didn't look to me like it was coming from the seal but it's drivers side in that general area. And your right what a mess. :mad all over the exhaust and baked on real good. Any slick ways to clean it that anyone knows?
Old Jan 28, 2003 | 10:57 PM
WMark's Avatar
WMark
St. Jude Donor '11
My '02's rear differential leaked by the time I brought it home, new. 27 miles on the car. Took it back, twice. They finally replaced the ring, the plate, and whatever. 10,000 miles, and no problem.
HOWEVER, a buddy in our club has had his differential leak three times. Of all the C5's in our local club, at least one third, if not more, have had the problem.
A few issues back, our NCCC Region mag had an article that mentioned complaining to a member of the Corvette plant management team, last summer. He acted like it was new news!!
Old Jan 29, 2003 | 06:42 PM
Ja4play's Avatar
Ja4play
Just an update.. Just got car back from dealer..they said the drivers side axle seal was not seated completely and so put in a new one..everything appears to be OK. no door dings and they only test drove it 3 miles. I'm :D :D
To Rear Diff leaking!
