Squealing rollers and drive belt.
Old Jan 27, 2003 | 11:29 AM
Dunno's Avatar
Dunno
Cruising
Default Squealing rollers and drive belt.
Hi
I recently bought a 98 c5 and since getting it it has starting squealing like a piggy! The rollers that guide the belt that turns the air con unit etc are noisy. I'm unsure which one at this stage but when I apply some oil to them they are quiet for 10 minutes. I'm worried that they may get worse and cause a major failure. The belt seems in good condition. Has anyone had this problem before and how do I rectify it.
Thanks in advance... Marcus :confused:
Old Jan 27, 2003 | 02:55 PM
lotzahp's Avatar
lotzahp
Default Re: Squealing rollers and drive belt. (Dunno)
You can try a search for "belt squeal" or stuff like that.
I had this problem at only 20k miles. Even though my belt LOOKED fine, I think it was glazed. I replaced it with a new OEM belt, and it still squealed. I put a Goodyear Gatorback belt on and it's been fine for 6k miles now.
I know of others who had to replace the idler pulley (next to the alternator). There was a TSB about a problem with that on 98's. Mine was OK though I have a 98 too).
I know of one other case where the crank pulley came out of alignment with the others, and I'm not sure what fixed that.
BTW: don't use the belt dressings - they makes matters worse.
Good luck!
Old Jan 28, 2003 | 04:24 AM
Dunno's Avatar
Dunno
Cruising
Hey thanks Lotsahp for your help.... I will post the solution here when I've fixed it.
:cheers:
Old Jan 28, 2003 | 06:29 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I've had several GM cars and trucks that use the serpentine belt, and at some point they all have gotten noisy.
I agree that a GoodYear belt is probably a good starting point, however I've also had to replace the tensioner pulleys on both my Camaro and my S-10 pick up somewhere before 30,000 miles. They just don't seem to last.
Old Jan 28, 2003 | 07:34 AM
200MPH's Avatar
200MPH
i also had the same problem on my 98. Just replaced the idler pulley and no more noise.
Old Jan 28, 2003 | 08:30 AM
Dunno's Avatar
Dunno
Cruising
Hi all
I can't understand why there isn't a way to test these components ie the idler pulley!!!
To Squealing rollers and drive belt.
