C5 TACHOMETER Problem
Old Feb 13, 2024 | 10:55 PM
Gbarnes's Avatar
Gbarnes
Default C5 TACHOMETER Problem
The tachometer on my 2000 c5 has quit working. It was working sporadically but now nothing. Any suggestions on where to start repairs?
Old Feb 14, 2024 | 09:15 AM
Missileboy's Avatar
Missileboy
When you turn the key on, does the tach dial sweep along with the speedo, but does not register RPM's when you start it? If it does sweep when you turn on the key, then that means the gauge is good but the signal to the gauge is interrupted somewhere. Have you pulled your trouble codes? Any codes present?
Old Feb 15, 2024 | 12:43 AM
Moved to C5 Tech for more discussion.
Old Feb 15, 2024 | 10:21 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Disregard
Old Feb 15, 2024 | 10:45 AM
mmartinez's Avatar
mmartinez
The sensor on top of the differential is for the speedometer not the tachometer. The tachometer receives its signal from I believe is the crank sensor which is a input to the PCM and the PCM sends an output to the tachometer.
Old Feb 15, 2024 | 10:47 AM
Stingroo's Avatar
Stingroo
Derp. You're right. Brain fart. Lol
To C5 TACHOMETER Problem
