Installed C5 longtubes, running terrible
Old Feb 14, 2024 | 11:10 AM
carson g's Avatar
carson g
5th Gear
Default Installed C5 longtubes, running terrible
Hey so I just installed longtubes and a catted x pipe and when I start the car the check engine comes on but I still have all 4 02 sensors but I’m getting codes for them and codes for misfires. Is this common? Will a tune fix this? Thanks
Old Feb 14, 2024 | 11:14 AM
smitty2919's Avatar
smitty2919
If misfire, double check plug wires are snapped onto coils and plugs. Double check you did not crack spark plugs during the job.
Once fixed, be sure to get a proper tune.
Old Feb 14, 2024 | 11:16 AM
Beast's Avatar
Beast
Yes, you need a custom dyno tune, check your spark plug wires, make sure they are connected and not touching the header. My automatic car dyno 340 wheel horsepower, I have a VR intake as well. A manual car should dyno 350-355 wheel horsepower. Take it to a dyno tuning shop.
Old Feb 14, 2024 | 11:17 AM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Sounds like you are in need of a good tune!
Old Feb 14, 2024 | 12:42 PM
LowcountryVette's Avatar
LowcountryVette
Make sure you have the o2 sensors plugged into the correct harness. Driver side sensor gets plugged into the harness on the driver side. People often get them switched up since the sensor points to the opposite side
Old Feb 14, 2024 | 01:44 PM
Dirty Dog's Avatar
Dirty Dog
Start by checking all your coils and wires for the misfire.
It's easy to plug the rear sensor into the front, or drivers side into passenger, and that'll cause problems And even though you installed a catted X-pipe (having breathable air will make your grandkids happy) you've changed the location of the cats relative to the engine. Which will affect numbers. Long tubs pretty much always require a tune.
Old Feb 14, 2024 | 03:36 PM
Eshoremd's Avatar
Eshoremd
2023 C5 of the Year Finalist - Modified
In the early 2000s I had a cammed, stalled, catless longtube camaro. Car was never tuned. Ran 11.8s at 118. Should you get a tune? Yes. Is that what is wrong? I doubt it. Like other mentioned, check you plugs, wires and connections.
Let us know what happens.
Old Feb 14, 2024 | 08:39 PM
Markolc1981's Avatar
Markolc1981
What codes are you getting?
Old Feb 15, 2024 | 12:42 AM
Moved to C5 Tech.
Old Feb 16, 2024 | 05:20 PM
lionelhutz's Avatar
lionelhutz
No, it will not. It shouldn't misfire and shouldn't have codes. Check plugs, plug wires and O2 plugs as others have posted.
Old Feb 18, 2024 | 07:38 PM
Tampa Tuning's Avatar
0Tampa Tuning
Former Vendor
St. Jude Donor '12
Default Corvette Tuner in Tampa
If you left your spark plugs in during the install, you may have cracked on, or pulled off the sparkplug wire.
You should not be having misfires from adding those modifications. The other issue for the CEL could be the moving or removal of the cats. Those codes would be normal for bolt ons with headers.
Phil
EMAIL: Tuning@TampaTuning.com
Website >>> https://shop.tampatuning.com/
CHECK OUT MY SHORTS : https://www.youtube.com/@tampatuning/shorts
Street Performance Tune Package starting from $390.00
Instagram: TampaTuning
Camaro Tuner in Tampa
To Installed C5 longtubes, running terrible
