heads and cam package suggestions
Old Jan 27, 2003 | 04:31 PM
esram's Avatar
esram
Default heads and cam package suggestions
I have an 02 vert. I have been told I dont need heads with an 02 beacause it came with the ls6 heads stock. is this true.
Thanks for the help. :party:
Old Jan 27, 2003 | 04:39 PM
Wt99C5's Avatar
Wt99C5
Default Re: heads and cam package suggestions (esram)
I'd say you have a LS6 block with LS1 heads.
Old Jan 27, 2003 | 04:40 PM
Moundir's Avatar
Moundir
NO, and even if did come with ls6 heads they can still be ported to make some serious hp. I really hope that the dealer didnt tell you that :nonod:
Old Jan 27, 2003 | 07:07 PM
johnnyC5's Avatar
johnnyC5
maybe they meant you had the LS6 intake manifold Stock.... not the heads.
[Modified by johnnyC5, 10:16 PM 1/27/2003]
Old Jan 27, 2003 | 07:23 PM
jimman's Avatar
jimman
Default Re: heads and cam package suggestions (johnnyC5)
You have intake and block Z06 but heads and cam are LS1 There is a performance upgrade that dosen't upset your warranty which includes the heads and cam. I was quoted 3800 out the door.
Old Jan 28, 2003 | 11:51 PM
hogurt's Avatar
hogurt
Default Re: heads and cam package suggestions (jimman)
:iagree: Most likely you have the intake and block. . .not heads.
Old Jan 29, 2003 | 09:43 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: heads and cam package suggestions (Buckmaster)
Being in Florida I would make the trip to Mike Norris.. :cheers: :cheers:
Old Jan 29, 2003 | 12:32 PM
Mr. Jones's Avatar
Mr. Jones
Default Re: heads and cam package suggestions (CHRIS NJ C5)
LS1 heads have #241 cast in them. You can find this number on the passenger side of the car at the front of the head where it meets the block.
LS6 heads are #246. Can someone confirm these numbers?
To heads and cam package suggestions
