Drivers side window not working
Old Feb 25, 2024 | 01:49 PM
billjazzy's Avatar
billjazzy
4th Gear
Default Drivers side window not working
All I get is a clicking sound when I press the switch. Bad switch??
2004 c5 coupe
Old Feb 25, 2024 | 02:50 PM
mmartinez's Avatar
mmartinez
Most likely a bad relay in the door control module, many members buy replacement relays, how are your soldering skills.
Old Feb 26, 2024 | 03:26 PM
mborgens's Avatar
mborgens
When mine was doing that, it ended up being the regulator/motor. I replaced the whole assembly and the issue was resolved.
Old Feb 29, 2024 | 09:52 PM
60 SHARK's Avatar
60 SHARK
Yep, mine also. Whole assembly is not expensive and several good YouTube how to videos will “get-er-dun”.
Old Mar 3, 2024 | 12:48 PM
rrwirsi's Avatar
rrwirsi
You might try the 'Window Wack" method before replacing anything. My passenger window would not work. Did the WACK method and all has been fine for 5-6 years. My electrical engineer neighbor said electric motors can develop flat spots in the wiring. He recommended routinely 'exercising the window'.
File Type: doc
To Drivers side window not working
