Leaf spring installation
Old Feb 26, 2024 | 10:39 AM
seturner's Avatar
seturner
Default Leaf spring installation
Hi,
I have read all the posts I can find about replacing the fron and rear springs, but I am still unclear on how to get the grooves in the support brackets lined up on installation. Since the spring will be at maximum arc, the rubber support bushings won’t align with the brackets exactly . Does anybody know a method to achieve this without buying the special spring compressor tool?
thanks
Old Feb 27, 2024 | 08:01 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Do one end at a time with a jack under the control arm. With the load on the spring it will flatten out and should seat the pads in the grooves. Get both bracket bolts started to make sure its centered, and then go back and tighten them down with load on the spring.
Old Feb 28, 2024 | 10:53 AM
seturner's Avatar
seturner
Thanks for the suggestion, that sounds reasonable.
To Leaf spring installation
