Ground location
Old Mar 10, 2024 | 09:18 PM
St.CharlesVette's Avatar
St.CharlesVette
2nd Gear
Default Ground location
I am getting the charging system fault after replacing the battery and alternator. Noticed this ground with no termination when I was looking at the starter. One end is on the engine, not sure where the other end goes. Could this be my problem and where do I terminate this ground?
Old Mar 10, 2024 | 09:38 PM
Lawandorder's Avatar
Lawandorder
Banned Scam/Spammer
Thats not a ground. That’s to keep the pcv valve from freezing over.
Old Mar 10, 2024 | 09:40 PM
Lawandorder
Banned Scam/Spammer
Charging system fault usually means you aren’t holding the key long enough when starting f the car.
Old Mar 10, 2024 | 09:52 PM
St.CharlesVette
2nd Gear
Should it be attached to the PCV valve? I will try holding the key longer on the next start.
Old Mar 10, 2024 | 09:54 PM
Lawandorder
Banned Scam/Spammer
If you’re in a warm climate you don’t need it.
To Ground location
