Wipers won't park, just click...
Old Mar 20, 2024 | 09:56 PM
1SharpGent's Avatar
1SharpGent
Default Wipers won't park, just click...
It seems like I fix one thing and another goes wild. Today's gremlin involves the wipers. I read a dozen threads and tried all the things, but I didn't come across a "clicking" like mine.
Udders are clean (been so for months). Everything is dry (parked in the garage on jack stands). Wipers were off without issue. I bumped the switch tonight and they popped up, and did the normal thing. I turned the switch off and they return to a "bottom" position on the windshield, but it's not parked AND (here's the fun part), they just make a clicking sound for 10 seconds, then swipe again. It sounds like the discs aren't aligned under the arms (the rotating pieces)? But why is this happening in the OFF position?
I think the clicking is it trying to park them. When the wipers are just ON (regardless of speed), they work great. Washer nozzles work great - everything's great.
I just can't turn them off because they won't park, so they click and fight. Anyone had this happen? I'm going to take the cowl off tomorrow and watch the movement – I'm just curious if anyone reads this and thinks, "yep, happened to me, here's the easy fix."
Old Mar 21, 2024 | 12:47 PM
1SharpGent's Avatar
1SharpGent
Came out this morning to check things out, turned the key, and they parked.
So I'm still going to open the cowl and see if I need to adjust the pin. After more research, I think the spring loaded pin isn't shifting into position to park (it's trying, hence the clicking). I had this issue on my Grand Prix GTP back in the day. Same mechanism. I'll post an update with images / instructions if it turns out to be an educational endeavor.
Old Mar 21, 2024 | 02:51 PM
RedVlvtChzCake's Avatar
RedVlvtChzCake
Warning, this may not be a super helpful reply, but I had the same issue happen to me several months ago.
I also saw somewhere to check the udders, but they were clean and everything was dry.
I unplugged the wiper fuse from under the glovebox, and drove to where I needed to go.
I put the fuse back in shortly after and have not had it occur again. I don't know if that fuse reset something.
Old Mar 26, 2024 | 03:22 PM
rrwirsi's Avatar
rrwirsi
Just like rebooting the computer, if it now works, do not look back and try to understand.. Electrical anomolies are evil!
Old Mar 28, 2024 | 09:34 AM
JHrinsin's Avatar
JHrinsin
There are times when I swear there are Minions living behind the dash and that either Kevin, Stuart or Bob need a good slap upside the head to get things working properly again.
To Wipers won't park, just click...
