Stuck Pilot Bearing
Old Mar 22, 2024 | 02:00 PM
whitelxne's Avatar
whitelxne
Default Stuck Pilot Bearing
Update: got the blind hole puller and the **** came out in a good 8 wacks. Punching the air right now
Old Mar 22, 2024 | 02:25 PM
lucky131969's Avatar
lucky131969
Originally Posted by whitelxne
Been wacking at this pilot bearing for two days, cars got 150k miles and the bearing looks rusted to the crank
got the autozone pilot bearing puller and grinded it down to fit into the bearing and it keeps slipping loose, the rollers from the bearing got ripped out and now i dont know what to do
Dont feel like getting the “blind hole puller”
any advice for a really stuck pilot bearing? can i use pb blaster on it to maybe loosen it a bit?
Don't feel like it? That's sounds like an emotional decision. Blind hole puller is your best next option. There is an oil seal back there, so don't get to creative.
Old Mar 22, 2024 | 04:08 PM
whitelxne's Avatar
whitelxne
its a financial decision lmfaoo i didnt want to spend more money if there was another way, hence why im asking
Old Mar 23, 2024 | 03:50 PM
Supercharged111's Avatar
Supercharged111
You sure you're getting the puller in there all the way? I suspect you aren't. It's going to slip out of the area where the roller goes, there's a lip behind that that you need to put the tool into and then beat the snot out of the thing. They're in there good and tight.
Old Mar 24, 2024 | 04:08 PM
whitelxne's Avatar
whitelxne
Welp. You were right. i got the tool and it worked like a charm 😭😭 thanks man
Old Mar 24, 2024 | 05:48 PM
lucky131969
Glad it worked out.
To Stuck Pilot Bearing
