Jerky throttle response
Old Jan 28, 2003 | 09:47 PM
TenaciousD's Avatar
TenaciousD
Default Jerky throttle response
In pretty much any gear (MN6), at various rpm levels, I'm finding the first 1/10th of throttle position seems to be more jerky than usual. What happens is that I'll be sitting in traffic, say in 2nd gear, fairly low rpms and I'll accelerate, but the car will jerk forward when I try to smoothly apply gas, and jerk back when I take my foot off the gas. It makes driving in traffic annoying, since I'm jerking back and forth no matter how smoothly I try to accelerate and decellerate. Anyone had this problem, or have any ideas? Throttle position sensor maybe?
Old Jan 28, 2003 | 10:20 PM
0-60N4's Avatar
0-60N4
Default Re: Jerky throttle response (TenaciousD)
My 2001 has some kind of similar problem... maybe. I call it surging. Especially when it is cold outside, Since I installed a Vararam intake, the car has this jerk occasionally when barely into the gas pedal. I removed the honeycomb in front of the MAF. No one seems to know what is causing it. It is a bit anoying... and embarrasing.
Old Jan 28, 2003 | 10:22 PM
TenaciousD's Avatar
TenaciousD
Default Re: Jerky throttle response (0-60N4)
Does it happen when letting off the gas as well?
Old Jan 28, 2003 | 10:28 PM
0-60N4's Avatar
0-60N4
Yes it does. Kinda weird. It feels like someone tapped the brakes or the engine just quit getting fuel for a brief moment.
Old Jan 28, 2003 | 10:31 PM
0-60N4's Avatar
0-60N4
You have IM.
Old Jan 28, 2003 | 10:34 PM
TooManyIDs's Avatar
TooManyIDs
You might try to get your hands on some measurement software and see if you are running lean.
In both your cases, your mods could result in leanness that has been attributed to surging in the past.
Old Jan 28, 2003 | 10:40 PM
TenaciousD's Avatar
TenaciousD
Default Re: Jerky throttle response (TooManyIDs)
I'm getting dyno tuning done in the next couple of weeks, so hopefully that problem will go away with a better a/f ratio. My last mod was long tube headers, so from what I've read a lean condition would make sense. Thanks for the replies! :cheers:
To Jerky throttle response
