Do I pull the motor to replace the Clutch while doing a HCI install?
According to the internet, the stock clutch won't be able to handle the new power I'll be making. So I purchased a
https://www.tickperformance.com/tick-monster-complete-clutch-swap-package-97-04-corvette-z06/
Now when it comes to installing the Clutch. Would it make sense to pull the motor at this point to do the Clutch?
Has anyone do it this way?
Would it be easier to drop the trans, torque tube etc and replace it that way?
I'm new to the C5 and this deepest I've ever dived into a vehicle. I'd appreciate insight from people with experience with this situation.
Thanks in advance.
You will have to lower the front cradle to get the engine out. Dropping the motor back in and lining the input shaft up on the clutch can be a trying job but doable.
If it were mine I'd pull the torque tube out and check the bearing couplers.
Pull the motor, reseal it. Uppper and lower pan, front and rear cover gaskets and seals.
Put the motor back in, bell housing / clutch on.
install the torque tube/driveline
Zip tie wires that go to the same post on the starter together. Take pictures or make notes as to which wire go to which post.
If you reuse the rockers look at the tips of the pushrods and where the pushrod rides in the rocker for anything that isn't smooth. Run your fingers tips along the surface check for anything that grabs you.
We ratchet strap the AC compressor to the frame, never disconnecting the lines.
https://www.tickperformance.com/tick...-corvette-z06/
Thanks in advance.
