torque converter suggestions
Old Jan 28, 2003 | 10:55 PM
esram's Avatar
esram
Default torque converter suggestions
Im running 3.73 gears, black wing, pedator, 4 inch ghl cat back. what stall should I use? this is a daily driver might see the track couple times a year. thanks for any help. :steering:
Old Jan 29, 2003 | 06:55 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: torque converter suggestions (esram)
ttt...VStella just did a great report on the new SS series from Yank....there's a lot of talk on the subject already, a quick search will produce several threads and that may help narrow down your search :cheers:
Old Jan 29, 2003 | 11:26 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
I am driing on a Yank ST 3500 right now with a 3.42 rear and it has very stock like manners on the street.
I am happy with the 60's it yeilds on the my car as well.
Old Jan 29, 2003 | 12:44 PM
Untouchable00's Avatar
Untouchable00
SY3500 is very nice. I thoroughly enjoy it.
Old Jan 30, 2003 | 12:20 AM
clancy's Avatar
clancy
Default Re: torque converter suggestions (Untouchable00)
:cool: YANK HAS A WEB PAGE THAT SHOULD HELP ANSWER MOST OF YOUR QUESTIONS.
CONVERTER.CC THATS ALL YOU NEED ENJOY. :cheers:
Old Jan 30, 2003 | 01:28 AM
gary brown's Avatar
gary brown
From: Los Angeles Founder, West Coast Corvette Challenge
Default Re: torque converter suggestions (Mean Green 2000)
You would also do very well to consider the YANK ST 3500 that Redgar mentioned. In either case, click here for a lot of usable information when considering upgrading your converter: http://www.converter.cc/ :thumbs:
Gary
Old Jan 30, 2003 | 03:41 AM
Face's Avatar
Face
Do you plan on using street tires, drag radials, or slicks?
If your only going to use street tires or drag radials, the SY3500 is a great converter. You'll probably still have a difficult time hooking up, but not as bad as going with a ST3500.
Old Jan 30, 2003 | 04:05 AM
MC98's Avatar
MC98
Default Re: torque converter suggestions (Face)
:iagree:
Mike is right I have the ST3500 and 3.73s you definately need at least DRs to hook up. The ST3500 is an awesome converter with great street manners, but the SY3500 would be better if you are going to be using street tires.
98 A4
Donaldson Blackwing
Cartek Stage 2 Heads
Cartek M Cam
LS6 Intake
TPIS Headers
Underdrive Pulley
Borla Exhaust
Comp Push Rods
Rev 1116 Valve Springs
LS1 Edit Tuning
172 t.stat
ST3500
3.73 Gears
B&M Trans Cooler
Old Jan 30, 2003 | 09:34 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
I am currently running a SY3500 with my 3.73s. (A perfect street racer setup if you're into that sort of thing, shame on you if you are. :nono: ) I like it with street tires a lot but from time to time wish I had gone with the SY4000. :sad: I'm swapping to the SS3800 soon as I plan to try to get to the track more this season. :rolleyes: :banghead:
Old Jan 30, 2003 | 01:36 PM
Face's Avatar
Face
Default Re: torque converter suggestions (ToplessTexan)
When I get my trans rebuilt, I'm going to send the converter to Yank and have them restall it to 4000 for me. IIRC, they only charge $250.
Old Jan 30, 2003 | 01:38 PM
gary brown's Avatar
gary brown
Default Re: torque converter suggestions (MC98)
:iagree: Mike and MC are absolutely correct. Street manners on both are great. I just see so many fellow modders going to better traction tires in the rear that I figure that to save money in the long run, you might want to get the converter with the better launch from a dead stop...and that would be the ST 3500.
If, on the other hand, you don't think that you will ever be getting a more aggressive tire, then I STRONGLY encourage you to take Mike and MC's advice and get the softer hitting SY 3500.
My own philosophy is to at least TRY and save some money down the road by attempting to anticipate what my future needs may be in terms of performance. I don't like doing things twice - or three times in the case of my converter setup. Just thought to try and save you a few bucks by not having to upgrade to a higher performing converter down the line. :yesnod:
Gary
Old Jan 30, 2003 | 01:50 PM
Untouchable00
Default Re: torque converter suggestions (gary brown)
Get the SY3500, 3.42s and TransGo!! Great setup!!
Old Jan 30, 2003 | 04:16 PM
vstella's Avatar
vstella
Im running 3.73 gears, black wing, pedator, 4 inch ghl cat back. what stall should I use? this is a daily driver might see the track couple times a year. .....esram
ANY aftermarket torque converter is better than the stock converter...IMO! BUT..If you don't invest in a set of Drag Radials ..don't bother ...you will just spin..spin...spin...Been there and done that!! :yesnod: Street tires and a 3.73 rear is not a good combination..there will little or NO traction :eek:
BTW..If you haven't installed the Transgo shift kit..DO IT!! You have NO idea what your missing..and you can't accomplish the same result with programming..no way..no how..Just my .02:D Good Luck!
Old Jan 30, 2003 | 07:26 PM
esram's Avatar
esram
Default Re: torque converter suggestions (vstella)
thanks for all the advice just ordered ss3600 from yank :steering:
Old Jan 30, 2003 | 09:11 PM
ToplessTexan
Somebody gonna be a happy camper! :thumbs:
Traction's no problem if you use that long skinny pedal with a little finesse.
Old Jan 30, 2003 | 11:15 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
:thumbs: I love mine, fastest 60' = 1.66 todate for me! Super Thruster
To torque converter suggestions
