C5 Corvette Odd Rear View Shifting Behavior
Old Mar 28, 2024 | 11:36 PM
Ikarah's Avatar
Ikarah
Default C5 Corvette Odd Rear View Shifting Behavior
Hello all,
I am a proud owner of a 2001 corvette I purchased recently. The car shifts very smoothly and I don't think anything is wrong with the clutch. However, I put it in reverse today for the very first time, it went into the position for reverse but I heard what sounded like a strange grinding or weird noise and when I hit the gas the car didn't reverse. I took it out of reverse tried again and it worked which was very odd with no grinding noise. Later I tried again in the day, it did the exact same thing only oddly the shifter moved on its own while it's in R almost further back and the reverse worked completely on its own but as i was reverse it popped back suddenly and went to N? I've never experienced anything like this on a manual. I read online suggestions about a fork or a solenoid but I am not sure I am experiencing the exact same issue here. Any advice would be great.
Thanks all.
Old Mar 29, 2024 | 01:50 AM
Moved to C5 Tech.
Old Mar 29, 2024 | 10:21 AM
rrwirsi's Avatar
rrwirsi
Mine will do the same grind dance for the 10 years I owned the M6. My fix; I first put in neutral then do a 'wiggle' with the shift'er, then put in reverse.
Old Mar 29, 2024 | 10:31 AM
Ikarah's Avatar
Ikarah
I'll try that next haha
Old Mar 29, 2024 | 04:53 PM
rrwirsi's Avatar
rrwirsi
Please post whether it works or not.
Old Mar 29, 2024 | 05:54 PM
Ikarah's Avatar
Ikarah
Yep, I'll give it a shot and lyk
Old Mar 29, 2024 | 06:02 PM
spfautsch's Avatar
spfautsch
Side note, what's happening here is the synchro slider isn't engaging the dog teeth on the reverse gear fully. Then when the clutch is released and the countershaft starts to move the dog teeth push the slider completely out of engagement.
This is a common problem with the t-56 and can be caused by a worn out (sloppy) shift linkage or by the reverse shift fork either being bent or simply not being shimmed correctly.
I think if the reverse lockout solenoid isn't retracting fully that could also cause the same symptom.
Old Mar 29, 2024 | 06:56 PM
Ikarah's Avatar
Ikarah
hmm.. what would be the fix for this?
Old Mar 29, 2024 | 07:20 PM
spfautsch's Avatar
spfautsch
Find out which one(s) is/are causing the problem and resolve them.
Easiest to look for would be a loose pinch bolt on the shift shaft in the tunnel, and that the upper shifter box cover bolts are tight and the mount bushings aren't disintegrated. This can be accessed from the top by removing the console.
Removing the reverse lockout solenoid from the transmission might be possible without dropping the driveline. Probably not a lot of fun, but I think possible.
The other two are going to require dropping the driveline and possibly disassembling the gearbox EDIT: which if you've gone that far you might as well anyway.
Whatever the case, if you hold pressure on the shifter in reverse while releasing the clutch it might help.
Just out of curiosity, do you still have the stock shifter or something aftermarket?
Old Mar 29, 2024 | 08:14 PM
Ikarah's Avatar
Ikarah
it's still on the stock shifter, I was going to swap it out with a short shifter thinking it would fix the issue
Old Mar 29, 2024 | 09:10 PM
spfautsch's Avatar
spfautsch
A shorter shifter will most likely make the symptoms worse and the car less enjoyable to drive because you're likely to be hunting for every shift gate.
Just another question out of curiosity, of all the vehicles you've owned, roughly what percentage were manuals?
I've only driven four or five t-56 cars. The way the shift shaft and wards are designed make them probably the worst shifting manuals in existence. Couple that with the C5's shift linkage with it's two pinned universal joints, and a shifter box that's kind of junk to start with (and doesn't age well) and you end up with meh.
My other Vette (a '95 C4) has a ZF6-400. Even though the shifter travel is almost twice that of the C5, it's far easier and more enjoyable to drive. And after 10 years I can count on one hand the number of times I've had reverse / 1st jump out of engagement due to limp-arming the initial shift.
Old Mar 30, 2024 | 11:18 AM
garllo's Avatar
garllo
Try doing a shifter alignment first. My ‘04is an automatic (can’t drive a manual anymore-medical) but the ‘98 that I had was a six speed. I had problems shifting into fifth gear. Did an alignment and problem solved!
Old Mar 30, 2024 | 11:44 AM
Ikarah's Avatar
Ikarah
I haven't had much manual cars about 2 of the cars I've owned. I did the neutral wiggle trick and it never failed to go right into reverse each time so not sure what that means.
Ikarah's Avatar
Ikarah
Excuse my ignorance here, a little new to manuals but, where can I get that done would any mechanic do this?
Old Mar 30, 2024 | 11:50 AM
ThomasR's Avatar
ThomasR
Reverse is like that in every t56 I've driven.
I hold the shifter on reverse and gently let the clutch pedal up an inch. The shifter clicks right in fully. If you're on a hill you can hold the shifter in reverse and let the car roll and it will fully engage reverse. You have to spin the input or output shaft for everything to line up sometimes.
Old Mar 30, 2024 | 12:23 PM
captain vette's Avatar
captain vette
My 03 Z06 trans behave exactly like yours, the trick I found is to go to first gear and just release the clutch a tad before putting it in reverse solves the grinding issue for me
Old Apr 1, 2024 | 11:12 PM
Ikarah's Avatar
Ikarah
interesting, so I am guessing this is somewhat normal. The neutral wiggle trick has seemed to work perfectly so far as of now...
Old Apr 5, 2024 | 09:38 PM
Ikarah's Avatar
Ikarah
This is kind of odd but, I've switched to a B&W short shifter and haven't seemed to experience much more issues so far. The old shifter was really beaten up to be honest.
To C5 Corvette Odd Rear View Shifting Behavior
