Car want start
Old Apr 3, 2024 | 02:11 AM
Grainraiser's Avatar
Grainraiser
Default Car want start
I replaced the battery in my car and now it will not start. It acts like it blew a fuel pump fuse but I have replaced it and it still will not start. I don't know were else to look. Any advise.
Old Apr 3, 2024 | 06:50 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What do you mean by “won’t start” ??…”No Crank” or “Crank No Start” ??
Old Apr 3, 2024 | 09:12 AM
lucky131969's Avatar
lucky131969
and post your Codes!
Old Apr 3, 2024 | 09:31 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Here is how to pull your codes without a code reader:
Old Apr 3, 2024 | 03:07 PM
Grainraiser
I will turnover but it will not start. I will try pulling the codes and report back.
Old Apr 3, 2024 | 03:25 PM
C5 Diag's Avatar
C5 Diag
Do you hear the fuel pump prime for 2 seconds when you turn the key on ??….if not you will have to diagnose the fuel pump system…if you hear the fuel pump feed an alternate source of fuel like BrakeKleen or my preference propane into the intake manifold…use PCV or brake booster….if car runs for a bit you have a fuel delivery issue….if car still doesn’t start look at your tachometer while cranking…if no movement this could be a crank sensor issue (no spark and injector pulse)…let us know.
To Car want start
