C5 difficult to put in reverse
Old Jan 29, 2003 | 09:08 AM
BBQ's Avatar
BBQ
Default C5 difficult to put in reverse
It seems like its getting worse. My M6 C5 doesn't want to go in reverse. I try re-engaging the clutch and it doesn't help. Any ideas? :confused:
Old Jan 29, 2003 | 09:14 AM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Default Re: C5 difficult to put in reverse (BBQ)
When my 6 speed was getting difficult to get into reverse, I found if I put it in 3rd first it would then go into reverse fairly easily.
Old Jan 29, 2003 | 09:15 AM
Chris Lemoine's Avatar
Chris Lemoine
From: You invited Eric? I thought Eric gave you the creeps!
Default Re: C5 difficult to put in reverse (CorvetteSS)
This is what works for me. Put trans in 1st shift to 2nd then over to reverse. I don't ever have any problems when doing this.
Old Jan 29, 2003 | 01:19 PM
see5's Avatar
see5
The problem is probably adjustment on the shaft that goes back to trans.
If you are a DIY guy email me and I will send you instructions.
Had the same problem.
Old Jan 29, 2003 | 02:33 PM
StickTail's Avatar
StickTail
Do you have the crappy stock shifter?
Mine gave me problems finding reverse.
Replaced it with a Hurst and ALL problems are gone.
Positive shifts so you always know what gear you are in.
No missed shifts to 3rd.
No binding while shifting in a corner.
Goes right into reverse like it should.
The Hurst rocks.
Best mod for the $$
Old Jan 29, 2003 | 03:08 PM
TNT C5's Avatar
TNT C5
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: C5 difficult to put in reverse (fdupny)
:iagree:
To C5 difficult to put in reverse
