C5 z06 harmonic balancer
Old Apr 5, 2024 | 11:44 AM
Howbtdemcowboys's Avatar
Howbtdemcowboys
Default C5 z06 harmonic balancer
I want to use an aa supercharger on my car in the future , can I use the stock balancer or should I upgrade it? And with what brand? And size?
Old Apr 7, 2024 | 05:03 PM
Tron Z's Avatar
Tron Z
Yes, you can use an OE harmonic damper. ATI and Summit dampers are probably the most popular. These are both SFI rated, which is important if you plan to race and/or beat on the car.
Most importantly, with a supercharger application, you will want to drill and pin the damper in place.
Have a look at "C&S Corvette" on the youtube. They have a couple of vids on dampers.
Old Apr 8, 2024 | 10:25 AM
Missileboy's Avatar
Missileboy
If you are putting that kind of money into your car, I would definitely spend another couple hundred and have a new balancer installed/pinned while you are getting the SC installed. The rubber does wear out on the stockers and eventually it will "wobble". You don't want wobble under load especially since you are adding another pulley to the system. This is one of those things that is only ~250 bucks now but could cause you a lot of heartburn in the future if it failed. You are already working in the front of the car for the SC install anyway, so this is the cheapest labor time to do it!
Old Apr 9, 2024 | 06:40 AM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Powerbond here- 5 years plus so far. Just the base balancer which is pretty common to use, I have only heard one person say they know someone with one of these that failed.... SFI costs double.
Long course road racing with extended high RPM, I would probably go with a better one.
Old Apr 9, 2024 | 11:49 AM
Howbtdemcowboys
its just a weekend car for some fun, not tracking it!! do you have a part number?? i love your youtube channel
Old Apr 9, 2024 | 11:59 AM
Howbtdemcowboys
to pin it you can just use the pin kit that comes with the aa supercharger correct?
Old Apr 9, 2024 | 12:10 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
A weekend car can still have a high RPM failure. Why cheap out on a balancer that's under $300.
Buy the Summit SFI balancer, pin it, and be done. SUM-C2501 is the part number.
Old Apr 9, 2024 | 12:37 PM
Moving to C5 Tech.
Old Apr 9, 2024 | 02:47 PM
Toys4Life C5
St. Jude Donor '21
Correct.
Old Apr 9, 2024 | 02:51 PM
Toys4Life C5
St. Jude Donor '21
There are links to it in the description of most of my videos. It's a well known balancer, highly regarded by most. Powerbond makes a SFI rated balancer as well - they are of course more durable and a must for some race series (tech requirement).
They also cost a lot more. Your call. IMO "Cheaping Out" would be buying some no name china balancer. The Powerbond has a good reputation - which says a lot.
Good luck!
Toys
Old Apr 9, 2024 | 03:13 PM
Howbtdemcowboys
does it matter if i go with a 6 rib or 8 rib balancer? i am going to go with the standard si and 3.8 pulley
Old Apr 9, 2024 | 03:49 PM
Stingroo's Avatar
Stingroo
If it has a six rib belt, you use a six rib balancer...
Old Apr 9, 2024 | 05:18 PM
Smoken1's Avatar
Smoken1
No it won't matter if you use an 8 rib balancer now. That just makes it easier to switch to all 8 rib set up when the time comes for more HP
To C5 z06 harmonic balancer
