does not want to start, sometimes
Old Apr 8, 2024 | 06:20 PM
R70chevy's Avatar
R70chevy
6th Gear
Default does not want to start, sometimes
Hi - I'm new the Corvette and have a problem I hope you can help me with.
I have an LS1 motor in my 2004 Corvette. The engine is stock except cold air intake, headers and a mild Crower cam. The issue I have is the car will start and then die.
If I disconnect the battery and let the car sit for several hours, I can get it to start and run. If I then turn the car off, I can get 1 or 2 more starts and it runs fine. After that, it will run for 5-10 seconds, then die. After that, it fires and immediately dies. After that, it turns over but will not start.
Here is what I have tried:
Fuel pressure is always between 58 & 62 lbs normal pressure - pump runs exactly how it should.
Confirmed all grounds are good and all connections are clean.
PCM has the battery connections and ignition connection correct. It has voltage when it should have voltage.
Confirmed VAT system is not the issue per the dealer
There are no pending or stored codes.
I have injector Diode I can plug into the injector wire, I have tried all 8, when it does not want to run it will flash a couple of times then stop. The car will run on brake cleaner or ether.
Help !!!
Old Apr 8, 2024 | 07:34 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If the car runs on an alternative fuel you have a fuel delivery issue…don’t know what this means…”I have injector Diode I can plug into the injector” ???…what is this ??
Old Apr 8, 2024 | 07:49 PM
Smoken1's Avatar
Smoken1
Noid light would be my guess
Old Apr 8, 2024 | 07:52 PM
R70chevy's Avatar
R70chevy
6th Gear
its like a small test lite that plugs into the injector wire. You can unplug the injector wire plug this little test lite in and it will blink if the computer is sending an impulse to the injector....
does that help?
Old Apr 8, 2024 | 07:53 PM
R70chevy's Avatar
R70chevy
6th Gear
Noid light correct
Old Apr 8, 2024 | 08:00 PM
C5 Diag's Avatar
C5 Diag
Never heard a noid light described that way !!…actually the noid light is not the best test of injector function since you are only seeing if the injector is powered and the PCM is grounding it…scoping injector current is way better…usually around 1 amp.
Old Apr 8, 2024 | 08:04 PM
C5 Diag's Avatar
C5 Diag
does that help?
Yes, but noid light is usually what it is referred to…you have a fuel delivery issue so I’d look at fuel pressure when it dies out.
Old Apr 8, 2024 | 10:57 PM
R70chevy's Avatar
R70chevy
6th Gear
when it dies its about 60PSI give or take a lbs or 2. this is from a mechanical gauge hooked to the fuel rail. I also tested the ohms in the injectors they are all at 12.3 or 12.4 ohms
The part I don't get is the noid lights up or blinks a couple of times and then stops, even if you keep cranking the motor. If its doing that, then there is no fuel delivery?
why does it stop pulsing? Is there something else in the computer that can shut it off?
I have been trying to work this problem out for about 6 months now...... just about ready to put a for sale sign in it.....
thanks for any help you can give.
have a great day
Old Apr 9, 2024 | 12:27 AM
C5 Diag's Avatar
C5 Diag
Maybe it’s a bad crank sensor…with a bad sensor you will not have injector pulse AND spark…if the car becomes a “crank no start” look at the Tach…if it doesn’t move while cranking it may be the crank sensor….a scope is the best way to see the signal.
Old Apr 9, 2024 | 12:30 AM
mmartinez's Avatar
mmartinez
PCM related possibly or wiring connections?
Old Apr 9, 2024 | 09:53 AM
mmartinez's Avatar
mmartinez
could be a bad crank position sensor or a bad cam position sensor as both work together to provide the pulses for the injectors and Ignition coils, I would inspect the wires that connect to both sensors.
Old Apr 9, 2024 | 01:24 PM
R70chevy's Avatar
R70chevy
6th Gear
thanks for the input, I will do that, the Tac does move when cranking
I will let ya know what I find
thank you !!!!
Old Apr 11, 2024 | 07:42 PM
mmartinez's Avatar
mmartinez
To clarify on my last post, the cam and crank position sensors provide output pulses that the pcm uses to generate output ground closures for the injectors and Ignition coils. Have you removed and inspected the connectors at the pcm, make sure the negative battery cable is disconnected.
Old May 15, 2024 | 04:09 AM
R70chevy's Avatar
R70chevy
6th Gear
Default update
I have replaced the coils, computer, injectors, fuel regulator fuel filter and main engine wiring harness. I have spark. When you turn on the key the pump primes to 60 psi. During cranking it drops to 50 to 55 psi and bounces back and forth, but will not start. Can a fuel pump put out pressure but no volume?
Thanks for the help
Old May 15, 2024 | 07:23 AM
C5 Diag's Avatar
C5 Diag
Thanks for the help
YES !!…checking volume is necessary as well as checking pressure before condemning a fuel pump !!
Old May 15, 2024 | 08:37 AM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
I had an intermittent no start on my 2K, a new cam position sensor cured my problem. Also had no codes set or pending.
To does not want to start, sometimes
