What is the correct offset?
Old Jan 29, 2003 | 11:44 PM
bennekm's Avatar
bennekm
Default What is the correct offset?
Anybody know the correct offset is for a set of HRE's. Looking to put 18x9.5 Fronts and 19 x 11 on Rears. I know the bolt pattern is 5x120.65, but have no idea of the offset for this size.
Thanks!
Old Jan 30, 2003 | 02:44 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Default Re: What is the correct offset? (bennekm)
It's 54 for the front. The rear kinda depends on what you want. If you do 58 it will stick out 1/4 inch more then a Z06 rear. If you want the same as a Z06 then it will be around 64-65
Old Jan 30, 2003 | 05:04 AM
C5 Frederik's Avatar
C5 Frederik
My OEM Z06 have an offset of
front 54 mm
rear56 mm
maybe this helps a bit.
Frederik
To What is the correct offset?
