Question about 243 heads
Old Apr 27, 2024 | 06:00 PM
Erikf555's Avatar
Erikf555
Default Question about 243 heads
I’m going to have a set of 243 Cathedral Port heads off a C5 Z06 CNC Ported, bowls blended, etc.
When I replaced the stock yellow springs and installed a CHE Trunion Kit I was pretty shocked at how crude and rough the stock cast rocker arm stand is. It’s so far from a percision piece that I find it hard to believe that the topic of throwing it out right away isn’t discussed much.
Am I missing something? It seems like absolute junk to me.
Can someone enlighten me on this?
Erik
Old Apr 27, 2024 | 09:37 PM
LowcountryVette's Avatar
LowcountryVette
What problem do you think it is causing? I haven’t heard of people having any issues
Old Apr 27, 2024 | 10:33 PM
Erikf555's Avatar
Erikf555
You are correct and that to me is the strange part. Have you ever held that piece in your hand? It’s incredibly crude in its casting and ready to use state for such an important role in the valve train.
I guess I’m overreacting. Just seems like the machining should be much better. However I will never ever be even close to as smart as the group that designed it.
Maybe I should just go to bed….
Old Apr 28, 2024 | 10:48 AM
redzg's Avatar
redzg
If they worry you, Livernois has you covered with CNC machined billet. Not free, duh, but for what they are not overpriced either:
https://www.livernoismotorsports.com...stock-hardware
Old Apr 28, 2024 | 05:20 PM
lucky131969's Avatar
lucky131969
Erik
Old Apr 29, 2024 | 12:33 AM
RonSSNova's Avatar
RonSSNova
The pedestals are machined as are the bottoms. I’m failing to see how the rest matters?
If I had any complaint it would be the depth of pedestals. Just have to be sure the rocker tip is straight over the valve when you tighten things down.
Old Apr 29, 2024 | 09:02 AM
lucky131969
It's just a gross misunderstanding on the OP's part of why parts are cast, and then receive a secondary operation for critical surfaces.
Old Apr 29, 2024 | 04:14 PM
G_Loc's Avatar
G_Loc
Originally Posted by CorvetteHeadz
Careful with CHE. high failure rate. Most ships use BTR
First I've heard of this. What kind of failures?
Old Apr 29, 2024 | 05:35 PM
G_Loc's Avatar
G_Loc
trunion
What about them? Are they cracking in half? Somehow wearing against the bronze bushing?
To Question about 243 heads
