PVC valve. With LS6. Yes or No ??
Hi. ... I'm confused here do l need to put back the PVC valve even when I upgrade the valley cover to LS6 (12577927) ??? Some they say yes some they say no , some videos in the YouTube yes some videos no. ??? So what ldo now ?
If the bottom of your valley cover looks exactly like the one you pictured, then that's an 04+ version and you do not need an external PCV valve.
The following 2 users liked this post by Prop Joe:
Markolc1981 (04-29-2024),
Mr. Black (04-28-2024)
[QUOTE=Prop Joe;1607759970]Depending on the year of the block, you may need to clearance/modify the block to allow installation. Not a big deal, have tools ready, and just cover everything with tape, towels, rags....
Before. Area needs to be removed on earlier blocks.
I used a whizz wheel to make a couple cuts. then went after it with a chisel. Crude but effective.[/QUOTE.
Can l ask you what's your block engine number 241 or 243 ?
Received 4,219 Likes
Super old crappy video of mine. Explains it all. Not promoting. No watch I won't be offended.
Received 19,584 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
[QUOTE=link9a;1607759996]
aren’t 241 and 243 cylinder head
Prop Joe (05-10-2024)
For all the kiddos joining the chat, it might be good to explain exactly what you achieved by replacing the valley cover and deleting the PCV valve. Especially since you had to cut a chuck out of your engine block to achieve the goal.
Performance increase? Reduced oil consumption?
I believe that is the sprue for the block during casting early years and not structural in any way. Later years blocks without the sprue there along that valley gasket surface are cast to allow more airflow down low near the crank, as well as missing that sprue.
I saw it here 1st.
http://www.ls1howto.com/index.php?article=18
I saw it here 1st.
Good old "ls1howto". I remember when that site first surfaced....the creator certainly knows no shame.
