I am reinstalling my LS1 intake and looking for tip or trick to get the tiny vacuum hose re-connected to the MAP sensor housing on the back of the intake when putting everything back together. I can't get my hand back there when the intake is on but the vacuum line is not long enough to connect if the intake is not on. I tried a search but did not find anything.
The "trick" I used is replacing that entire run of vacuum line with old fashioned hose, separate of the harness. It was a PITA b/c you have to remove the left fender to get to the end that connects to the HVAC stuff, but it makes pulling / replacing the intake a 30 minute job with zero cussing.
Yep, tough lessoned learned. I extended the vacuum line the first time I took my intake off. It will take you less time to remove the intake and modify the line than finding a creative way to get it connected with the intake installed.
I added a 'nipple' vacuum hose splice fitting and extended the vacuum hose with an extra length to this splice when I replaced the knock sensors. I hope to never have to R&R the intake manifold again, but I could now do so easier with the longer hose fitting. It certainly lets you know that the whole engine was installed with that vacuum line already plumbed when GM built the car. Not only do your hands not fit, but you can't get your eyeballs back there to see the hose or the MAP fitting.
