Gauge cluster/IPC Not working.
Old May 3, 2024 | 11:07 AM
AFVsolidC5's Avatar
AFVsolidC5
Default Gauge cluster/IPC Not working.
My car is a 97 auto, I retrofitted it with a heads up display and newer cluster back around 2010. The car has been covered and on the battery maintainer since around November, first start of the season and I have no gauges. They do not sweep, the HUD displays two dashes, the data display is blank and the buttons do nothing. Certain things light up on the dash, the check engine light, emergency brake light and flashers, there is no door open chime. I have checked fuses 19 and 25 both are good and the voltage on both sides of them read 12 volts with the key on. I'm trying to decide what to check next, the car starts and runs fine.
Old May 3, 2024 | 03:03 PM
rrwirsi's Avatar
rrwirsi
Mice attack? They love storage cars.
Old May 3, 2024 | 03:47 PM
lucky131969's Avatar
lucky131969
Connect a scan tool up to the OBD 2 port and see if you can pull codes if the DIC is not working.
Old May 4, 2024 | 11:09 AM
AFVsolidC5's Avatar
AFVsolidC5
No mice anywhere as far as I can tell, I just hooked up my scan tool and it is telling me it has no codes, which is odd because I normally have at least a steering wheel position sensor code, but maybe they are all clear from having the battery unhooked. I can read all sensors like normal. I have also noticed that my fog lights are not working. I tried unhooking the top star connector beside the bcm like I read in an older post but that didn't change anything. Thanks for the replies.
Old May 5, 2024 | 08:08 PM
redzg's Avatar
redzg
I would try disconnecting and reconnecting the battery again as well. Dang car seems to reprogram itself every time the terminals touch. Also, make certain the terminals are clean and tight.
Old May 6, 2024 | 01:20 PM
AFVsolidC5's Avatar
AFVsolidC5
I think I may have found the problem, the board and connector is corroded. Any tips on cleaning it? Toothbrush and alcohol maybe?
Old May 6, 2024 | 02:48 PM
redzg's Avatar
redzg
Personally, I think I would tend to spray electrical contact cleaner first, possible followed with a small glue or acid brush. I worry about cotton swabs catching fibers on pin ends.
Old May 6, 2024 | 03:58 PM
lucky131969
Yep. Make sure your workstation and you are grounded.
To Gauge cluster/IPC Not working.
