Mufflers only help needed
Old May 6, 2024 | 10:26 AM
Ritch85's Avatar
Ritch85
Default Mufflers only help needed
I bought my C5 as is. It has heads, a cam, headers, big long tubes headers and then straight pipes. It was fun at first, but now it's a bit obnoxious starting it at 4:45am for work. My neighbors haven't verbally said anything, but seeing them when I'm coming home from work, I do notice a lot of side eyeing.
Anyway, I am looking for recommendations on just a low end muffler/s I can cut the pipes currently on the car and weld the mufflers into place.
Old May 7, 2024 | 11:26 AM
redzg's Avatar
redzg
The problem is space. To fit in the recesses you need mufflers similar to OEM, with inlet and outlet on one end. There are a couple of brands that have them, and I believe they are 2.5”, but no idea how restrictive they are.
Might I suggest a perusal of Facebook marketplace near you for an original system? They tend to be cheap other than shipping, and a cordless Sawzall would make retaining what you need a quick proposition.
For new mufflers tucked up and in, Summit has an option:
https://www.summitracing.com/parts/w...hoCC5kQAvD_BwE
Old May 7, 2024 | 12:54 PM
Mc556's Avatar
Mc556
BTR stage 3 cam, no cat, 1-7/8th long tubes with x pipe and a Corsa sport exhaust. Sounds amazing after the cold start idles down. At cruising speed no drone and very quite for what it is. I do have a truck divider ( z06). WOT sounds mea
Not a low end muffler. If you want cheap your best bet is a stock TI z06 with the bypass mod deal.
A used Borla if you can find one.
I keep trying to upload a 9sec clip but it’s not working
Old May 7, 2024 | 02:14 PM
smitty2919's Avatar
smitty2919
Dynomax 17676 mufflers
I used a stock base car catback over axle pipes and added the mufflers. A simple 9" bend and a tip finished it off. Later project was adding a custom butterfly valve in a bypass pipe.
Old May 8, 2024 | 07:38 AM
redzg's Avatar
redzg
Nice photo — but a short clip with sound would be incredibly helpful.
Old May 8, 2024 | 11:46 AM
smitty2919's Avatar
smitty2919
It's a mix between a flowmaster and magnaflow. It is a packed muffler but does have a slight deep hollow tone.
Magnaflow and Flowmaster I believe both offer same side dual in mufflers in 2.5" design.
All depends on the tone/sound you want.
To Mufflers only help needed
