Leak between tranny and diff?
Old May 6, 2024 | 04:42 PM
keanezheng's Avatar
keanezheng
Default Leak between tranny and diff?
I started to see drops of fluid on the floor (seems like tranny fluid since it is red). But couldn’t find where it came from.
so I pressure washed the diff covered with dirt and grease (probably from previous leaks), wiped and wire-brushed as best as I could.
I also serviced transmission last winter, drain and fill, replaced the filter and gasket, torqued the pan bolts to about 140 inch/lb. But this leak appeared before the service in case you might think I messed it up due to my gasket replacement. No leak around the pan gasket it seems.
Now if I leave the car parked for weeks, no leaks. If I take it for a drive, there are small amount of fluid coming from where trans connects to the diff.If I don’t wipe it off, and keep using the car, it will then form drops on the floor. I suspect when the car heats up, the fluid expands, and somehow breaches the seal there. Picture is attached. Is this a bad problem? What is the fix? Can you simply apply some sealant there?
Old May 11, 2024 | 12:42 AM
Moved to C5 Tech.
Old May 11, 2024 | 02:20 PM
c5arlen's Avatar
c5arlen
That particular GM leak tends to come and go... Evidently you and I are the only ones concerning this leaking Corvette being regulated outa the main flow... Bummer
Old May 16, 2024 | 05:04 PM
hmhaga's Avatar
hmhaga
https://www.z06vette.no/2023/09/m12-...-leak.html?m=1
Another source of oil leaks are the inner and outer rear seals of the extension housing, so I changed these too while they were accessible. If you have red ATF oil leaking between the transmission and the differential, these seals have failed
Old May 20, 2024 | 03:42 AM
keanezheng's Avatar
keanezheng
Did you do anything?
I searched some threads, and people seem to put RTV where the leaks come out. I have no intention to take the diff out for this....or I might as well sell the car due to the cost. Can't do that myself. But rubbing that area with some RTV sounds attractive. I got some JB Weld products and will try it this week.
Old May 20, 2024 | 03:46 AM
keanezheng's Avatar
keanezheng
Oh wow, very good article. Thanks, although mine is auto, but the symptom looks very similar.
That is a crazy repair that in no way I will do. I didnt read it through carefully, but will do when I have time.
To Leak between tranny and diff?
