Auto surges forward when started
Old May 15, 2024 | 08:55 AM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
Default Auto surges forward when started
I have noticed when starting up after a few days sitting or when cold my 2K auto will surge forward a bit on initial start, as if the clutches are somewhat engaged. The trans has 124,000 and as far as I know it is untouched. I have no experience with a 4L60, is this a trait of this trans or something more devious? TIA
Old May 16, 2024 | 01:36 PM
RonSSNova's Avatar
RonSSNova
Mine does that. It hardly lunges forward. I just notice the car moves a smidge.
Old May 16, 2024 | 08:27 PM
twostepdon's Avatar
twostepdon
My 2001 with 158,000 miles on it is like RonSSNova but it is not consistent.
Old May 16, 2024 | 09:51 PM
redzg's Avatar
redzg
Not to be a smartass, but use of the parking brake will put an end to the lunge.
Old May 17, 2024 | 09:27 AM
cdee63's Avatar
cdee63
Not worried about it getting away, just curious. Like others mentioned it is just a small movement. Must be a GM thing, I bought a 2024 Malibu new yesterday and it does it as well. The lever actuated parking brake is only good for getting the rear end to come around in the snow when the front's start understeering...
Old May 17, 2024 | 10:53 AM
Mc556's Avatar
Mc556
You have gotten a lot of life from the 4l60e lol
If your in park and surging forward and converter was locked I’d imagine you would stall like a 6 speed would.
I’m not a transmission guy so take my comments as such. Could be as simple as a fluid filter service or maybe a servo that is easy to access at the same time.
Could be a failing converter or transmission that needs replaced. If that’s the case then the transmission is coming out. Refresh the transmission if it comes out. That’s and a Re manufactured converter should be around $600 not including labor to pull the transmission and reinstall.
Pulling and reinstalling is a whole different conversation.
Old May 17, 2024 | 11:29 AM
jim993's Avatar
jim993
If the transmission has had the same fluid and filter for 124,000 miles it is time for a fluid and filter change. My A4 has 120,000 miles, 28 days on road course race tracks and approximately 10,000 wide open throttle upshifts from 2nd to 3rd on it. But I have changed fluid and filter five times and only use Red Line full synthetic fluid. The car does not move at startup.
To Auto surges forward when started
