2000 Clutch Replacement
Old May 16, 2024 | 10:56 AM
LebowskiC5's Avatar
LebowskiC5
Default 2000 Clutch Replacement
Hi everyone,
Getting a list together for a clutch replacement on my 2000 z51. I want to do as much as possible while I have everything dropped. Here is my list so far:
Clutch Kit - Tick LS7 kit
Master Cylinder - LUK LMC372
Slave Cylinder - Tick 24264180 (includes shim kit and remote bleeder)
Pilot Bearing - GM PN#14061685
RPM Torque Tube Rebuild Kit, with rubber couplers
Rear Main Seal - PN#89060436
Trans Tailhouse Seal - PN#12369456 (this is leaking and I would like to address while I have everything dropped)
26 spline clutch alignment tool
Pilot bearing puller
Looking around $1300 just for parts, not including tax or shipping.
Did I miss anything?
Old May 16, 2024 | 12:03 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Rear main cover gasket for the engine. Sometimes you can buy a new rear cover, mail seal, and cover gasket as a package for less than the gaskets.
A metal clutch allignment tool helps get things line up.
Remote clutch bleed if you don't have one.I'd go Tick
We have rented a slide hammer tool from Advance or Autozone to get the old pilot bearing out.
Old May 16, 2024 | 01:05 PM
lucky131969's Avatar
lucky131969
Originally Posted by LebowskiC5
Hi everyone,
Service manual ?
Old May 16, 2024 | 02:13 PM
LebowskiC5's Avatar
LebowskiC5
Originally Posted by lucky131969
Service manual ?
Not yet, but actively working to buy a preowned set.
Old May 16, 2024 | 02:16 PM
acroy's Avatar
acroy
Looks pretty comprehensive. Have fun!
To 2000 Clutch Replacement
