Updated pcv valve from GM
Old Jan 30, 2003 | 08:37 PM
David Plum's Avatar
David Plum
Default Updated pcv valve from GM
New to me GM pcv valve part # 12572717 dealer is installing for oil consumption.
Old Jan 30, 2003 | 11:42 PM
Jason Blue Boost's Avatar
Jason Blue Boost
Default Re: Updated pcv valve from GM (David Plum)
Is this an O3 part? What part or part number is this replacing? I'm about to order my LS6 valley cover with the LS6 pcv tube part# 12573109. Thanks :confused:
Old Jan 31, 2003 | 12:47 AM
martinsw's Avatar
martinsw
If anyone knows more about this chime in and share the wealth!
Maybe we can all get rid of our pvc mods :D and just put this new gm pcv (different from pvc ...letters are different!), but I, for one seriously doubt it. :skep:
That would be giving the GM engineers to much credit IMHO :lol:
Steve
Old Jan 31, 2003 | 08:07 AM
marco383's Avatar
marco383
Default Re: Updated pcv valve from GM (martinsw)
Just slightly off topic, but how difficult is the Z06/PCV mod for an average home wrench? Also, roughly how much does GM get for the required parts?
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Replacing the PCV with a new style will not SOLVE this issue.. the oil coming up the tube towards the PCV still needs to go somewhere... if the PCV prevents the oil from getting past it, where does all that oil go???
Just wondering??
Old Jan 31, 2003 | 09:16 AM
6Speeder's Avatar
6Speeder
Default Re: Updated pcv valve from GM (nevrenuf)
The new PCV operates differently than the old. It just has a small orifice, no spring and check valve. Suppposedly, the smaller opening pulls less air under vacuum, hence pulls less oil into the throttle body. I bought one, MAYBE it is helping my consumption, too soon to tell. :cheers:
Old Jan 31, 2003 | 10:09 AM
SteveL2's Avatar
SteveL2
Default Re: Updated pcv valve from GM (6Speeder)
:iagree: -- I had one PCV mod on my car, and I took it off when GM put this new PCV valve in my car during an oil consumption test. I think it helped a little on mine, but not enough to prevent a re-ring. Hoewever, once I got the new rings, I kept the new PCV without going back to the PCV mod, and with 3k miles I haven't had any problems.
Old Jan 31, 2003 | 11:41 AM
white top's Avatar
white top
Post on C5Forum by c4c5tech said this PCV not for LS1 but for truck engine
derivatives of LS1. One who used it reported whistle at WOT.
Old Feb 1, 2003 | 09:55 AM
6Speeder's Avatar
6Speeder
Default Re: Updated pcv valve from GM (white top)
Mine isn't whistling, I just don't know if it is any better for oil consumption yet. :steering:
To Updated pcv valve from GM
