Power Windows Problem
Old May 20, 2024 | 08:50 PM
GaryGarrity's Avatar
GaryGarrity
5th Gear
Default Power Windows Problem
Both my windows on my 2000 Converible wont go up!
The other functions ie mirror adjustment and seat set work just no windows. Tried disconnecting the battery for 30 minutes No luck.
Using my Ancel programer it showed
Componenti ID #20 and ID30 with red x
All the others were green.
Where do I go from here?!
Old May 21, 2024 | 03:24 PM
rrwirsi's Avatar
rrwirsi
Try jiggling the according tubing between the door and the body. The connection between the door and body within the tubing has a history of working loose. If that does not work, then work the wiring out of the connecting tubing and make sure the connector is tight and clean.
Old May 21, 2024 | 04:52 PM
lucky131969's Avatar
lucky131969
No idea how ID #s correlate to DTCs
https://www.corvettesalvage.com/c5-c...ics-explained/
Post your codes.
Old May 21, 2024 | 07:00 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Read the DIC it will tell you if the door control module is ok. If you don't know how to do it an internet search will find the instructions.
Old May 21, 2024 | 07:42 PM
lucky131969
To Power Windows Problem
